Old 25th October 2006, 05:08 AM   #1
ROVSING is offline ROVSING  Denmark
ROVSING's Avatar
Default Heatzinking before and now...
Might be an FAQ question...sorry
I have attached a picture wich shows different heatzinks
To the left from a denon pma 850 (28 years old) 85w with 1 outputpair / ch 6,5 kg toroid 2*2*40v AC
To the right from a NAD 3080 100w 2 outputpair/ch 6 kg trafo
1*ct 26,5 v AC
And behind those wich i have used fore my KSA 50 with 3 outputpairs/ch
In that case i was recommended to use fans too, even though that the heatzinks are big.
Most amplifiers build in this forum got huge heatzinks and my main question is, what makes the difference from older heavy gear till new heavy gear ?
Before i decided to take the Denon apart i played with it and it never did get very hot-and it was class A ....
Frandsen
Old 25th October 2006, 05:11 AM   #2
ROVSING's Avatar
And heres a picture of my KSA 50 so far, i won't be able to keep my promise in the KSA50 forum (finished before reply no 7000)
Frandsen
Old 25th October 2006, 08:12 AM   #3
djk is offline djk
djk's Avatar
Both the Denon and the NAD are class AB amplifiers, the bias was quite low on them.
Old 25th October 2006, 08:18 AM   #4
ROVSING's Avatar
Ok djk, but on the back of the denon, it says POWER CONSUMPTION 600 Watt, isn't that much for a class AB ?
Or am misunderstanding the meaning of that ?
(Could be my english skills cheating me)
Frandsen
Old 25th October 2006, 08:41 AM   #5
ilimzn is offline ilimzn  Croatia
The power consumption rating on the back is given as a MAXIMUM and normally also includes any switched AC outlets the amp may have, sometimes also the unswitched. In other words, unless you know how it's wired internally, and sometimes not even then, it's a pretty much useless figure.
Page generated in 0.08407 seconds (75.50% PHP - 24.50% MySQL) with 10 queries
