I have built a Slone's OptiMOS with SMD implementation of the low-power part on a double layer PCB 160 mm x 50 mm. Input transistors are BC850C / BC860C, the SMD version of 2N5551 is MMBT5551, driver transistors are 2SC3421 / 2SA1358, output is "standard" 2SK1058 / 2SJ160. Powered by +/- 50V. The output transistors are biased to approx. 40 mA without signal. It sounds great - very good detail, powerful bass. The problem with it is I get an audible noise when listening at lower signal levels. If the CD player is not playing, nothing is to be heard, but when it starts, at low volume levels, noise is to be heard as high as the signal. I am afraid my amp is ringing... but unfortunatelly I don't have an oscilloscope. I would be glad to hear some ideas what could cause such a noise, and what could I try in order to find out what is happening. Thanx!
GeleTheMaster / SINIGERSKY AUDIO |
#2 |
What kind of noise? Buzzing, whistling, white noise?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
I would call it white noise, like the noise of a casette.
#4 |
Short the amp inputs, and see if the noise is still there. I suspect however that the problem is with your CD player...
#5 |
I have built 3 dual monoblocks of the Optimos and they are all dead quiet. The only noise is the mechanical vibration of the big transformers. They hum from time to time.
Regards, Bill |
#6 |
Check grounding/wiring.
#7 |
Which book did G.R.S. publish the OptiMOS design in? I have his Tab Electronics book and his High Power Amplifiers book, and he doesn't give names to the amps, though in the final design of the latter book, he refers to it as an optimized MOSFET design. Is this one, or is it published in the book I don't have?
..Todd |
#8 |
As all the friends suggested check all of that, plus you could lift your inputs ground by connecting a 10 Ω resistor from inputs ground to ground. Also instead of the resistor you can put the same way a thermistor like a keystone CL 60. It has exactly the same resistance and is for 6A. Thermistors also can be used as surge supressors if you connect it on the primary of the transformer.That is from the great Nelson Pass. Check also your wiring if it passes close to the transformer it picks up noise.I hope gave you an answer.
#9 |
Have u connected the shield on both sides of the interconnecting cable...
Gajanan Phadte |
#10 |
Yes absolutely , otherwise there is no connection.
| Two noise problems on two different NAD 216 THX | ratep2001 | Solid State | 1 | 4th January 2009 01:05 PM |
| Please Help, 2 different noise problems in system, | britcye | Car Audio | 6 | 28th February 2006 02:14 AM |
| new sub/amp and noise problems? | duece212 | Car Audio | 2 | 22nd November 2004 08:46 PM |
| Aleph 3 bass/noise problems | bigmernisher | Pass Labs | 10 | 6th June 2004 09:31 PM |
| Noise problems with HP amp | kmt | Analogue Source | 1 | 17th March 2004 07:10 AM |
| Page generated in 0.12577 seconds (77.58% PHP - 22.42% MySQL) with 10 queries |
