Starting a new thread for a new circuit. Moderators if you feel this should be merged with "my simple class a approach" please do so.
Here we have the same output stage as before with a basic discrete opamp frontend, split rails, and no coupling capacitor. |
#2 |
You can omit R2 (replace it with a short)
#3 |
Yes it can be shorted and still work the same. A current mirror would be better hear but this is just a preliminary circuit for concept. Values and all are not final as I am in need of some help with diffrential circuit and frequency compensation.
#4 |
Your C3 looks too high for me.
#5 |
Without C3
#6 |
With C3
#7 |
I am not so keen in construktion,but Wouldn´t a more "modern" transistors make the amp work better?
Regards Åke |
#8 |
Better transistors always will work better. I model with I have on hand to build with for the first "test" circuit. Speaking of which I spent the last couple hours building it. It is only very basic build without "real" ccs's but the sound quality is good. Offset at the output is more than I would like but improvments can be made to lower it easily.
| simple class D amp | latala | Class D | 21 | 5th April 2009 05:13 AM |
| SImple class D amp | croccodillo | Class D | 0 | 29th May 2008 01:56 PM |
| Simple class B or AB amp. | Mr Evil | Solid State | 3 | 21st August 2004 12:58 AM |
| Page generated in 0.09124 seconds (75.65% PHP - 24.35% MySQL) with 11 queries |
