Nishiki hybrid amp
Nishiki hybrid amp
Old 5th March 2012, 07:28 AM   #81
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
Hi all!
Please let someone views the original scheme Hybridnog amplifier with PCC88/(2SK176/2SJ56) from Elektor 1997.
Thank you
Old 20th April 2013, 07:24 PM   #82
Bangla H is offline Bangla H  Germany
Bangla H's Avatar
Hallo an Tyimo.
I mean you schould build the Nishiki.
I've download the manual from Wims Site and going to build it.
The 6N1P-EV i use for SRPP or Cascode called Input. The Comment who Other DIY'ers
wrote is right. A real Frontstage, i would say frechness, detailled in the Highs. First listening i was very impressed. The Amp works without Velleman but with R+L 15 Ohm
and around 6,3mm 16 turns o,75 Cu- Wire. It gives no on/off Plopps to Speaker.
The Choke is a Hammond 156L 5H, 75mA, 135 Ohm works pretty.
I like the Sound of the Amp but i must finish it to a nice Case.
Thanks to Wim that we DIY'er can build a amazing Amp.
Old 20th April 2013, 08:43 PM   #83
lineup is offline lineup  Sweden
lineup's Avatar
Originally Posted by formula 22 View Post
Hi all!
Thank you
I have found an old article about the Hybrid from Elektor 1997 August.
I attach here a picture with simplified schematic.
But you have to guess the values of resistors.
So, if you want some details, you have to search the web for more information.
I could send you the full article in PDF, if you give email.
lineup
Old 21st April 2013, 03:13 PM   #84
Cambe is offline Cambe
Where can I get PCB's for this amplifier?
Lineup, may I have a copy of the the pdf's for this amplifier, please.
harry.cmpbll@gmail.com
Old 23rd April 2013, 04:47 AM   #85
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
Hi, I also want to build this amp, but i want to use the original 6N3P input and 6n1p Cathode follower buffer...did you use 6n1p-ev for both? What output transistor did you use>.. can you share your schematics?
Old 4th May 2013, 07:45 AM   #86
Bangla H's Avatar
Hi Junm.
Old 4th May 2013, 08:31 AM   #87
Bangla H's Avatar
Hi also Junm.
In my old pc have These The Nishiki Amp 4.1 PDF Manual. See also
Read technical manual nishiki 41 + d.PDF
http://www.readbag.com/wimdehaan-nl-...alnishiki41the Link, hope it works, you can find all Details.
In my ippinion also the Nelson Pass ideas: simple is better you schould build first the
6N1P-EV Variant.
The Coppel C is Clarity SA 4,7, Q1- BD679; Q2,3 2SC4382, 2SA1668 Sanken Hfe matched and the LAPT 2SC3263 in the Output.
My Inspiration was to listen the Quasi Comp. Output like Quad or Naim Amps. The Valve i know from test as Tube Buffer with LM3886 from China Jims Audio.
From Mikel Chua- AmpsLab i've bought and wired 2xLM60 SJ162/SK1058 LatFet and i know they are relaxed to listen every Day. But im on Search.
Now i would like Test Papa Nelsons Amps F4, F5, F5Tv2, Mini Aleph, Amp Camp Amp
a lot of work i have to finnish.
In the PSU of Nishiki HV D1-4 BYV96D used C3 is Audyn Q4.
For Tube Heating i add a 1,8Ohm/5W to got 12,6V.
Don't Forget i'm a DIY'er how spend some Time with HiFi- Hobby.
I'm not sure i mean that Wim de Haan was a Part of Constructors the Elektor
Mugen Hybrid Amp?
Hope i was helpfull.
Best Regards. Bangla H
Old 6th May 2013, 01:23 AM   #88
Junm's Avatar
hi Bangla,
Thanks....I have the same manual (pdf) long ago but not enough time to start with. I plan to used 6n3p+6n1p and the output is quasi comp with MJL21193...Also want to try 6N23P+ 6N6P combo and Bridge the output stage since my PSU is only +/- 25vdc for the output and 250-300Vdc for the input.
Old 28th September 2015, 05:01 PM   #89
krowaklara is offline krowaklara  Poland
anybody knows new mr. Wim de Haan webpage?
Nishiki hybrid ampHide this!Advertise here!
Hybrid nitelite Tubes / Valves 4 16th November 2013 09:32 PM
the hybrid one arhi45 Tubes / Valves 11 8th May 2007 08:44 PM
Hybrid Ply / MDF ? Renron Multi-Way 5 8th February 2007 10:49 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
