Nishiki hybrid amp - Page 2 - diyAudio
Old 1st November 2006, 06:37 PM   #11
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by teodorom
Yes, please.
Originally posted by Tyimo
Hi Lineup!
Me too please!
Tyimo
Okay, I have a look into my many magazines
and try to find that very issue, may take some time
because 100 of magazines to search in.
But my guess hybrid article was around years of 1990-92.
The project was very complete.
With detailed supply circuits and even protection circuit.
And also every subcircuit had PCB layout and pictures of PCB, too.
I clicked your www homepage, teodorom.
You sure have a lot on the mathematics of Tubes.
I bet you have the most good SPICE simulations
anyone can do, when it comes to TUBES!
http://teodorom.atspace.com/
Think there are many tube lovers in Italy!
Think about Andrea Ciuffoli website!
Absolutely one of best TUBE SITES in THE WORLD
http://www.audiodesignguide.com/
He has got some unique and good Solid State projects and schematics, too!
lineup
little audio amplifier website, under construction
http://lineup.awardspace.com/
lineup
Old 1st November 2006, 07:36 PM   #12
lineup's Avatar
Smile Tube MOSFET Elektor Hybrid 1997
Okay,
it was 1997 this Tube MOSFET Elektor Hybrid was published.
What semiconductors are used?
Tube:
PCC88
Voltage supply = 138 VDC
Heater: 7 Volt, or better one 300 mA constant current
MOSFET, complementary output:
2SK176 + 2SJ56
at 100 mA idle current = Class AB
and 2 x 42 VDC supply
Data:
65 Watt RMS into 4 Ohm
-1.7 dB at 100 kHz
___________________________
Comment from article:
Also 2SK175 + 2SJ55 can be used.
If lowering supply voltage ( 2 x 30 VDC )
it is said, that you can use IRF HEXFET:
IRF530 + IRF9530 or IRF540 + IRF9540
at about max 50 Watt output.
Attached is the very few parts Tube Circuit
The electrolytic capacitor C1 is 470 uF.
lineup
Old 1st November 2006, 07:38 PM   #13
lineup's Avatar
Here is attached how the Tube PCB looks.
At a real photo!
See Circuit in previous post.
lineup
Old 2nd November 2006, 01:05 PM   #14
Hello!
I'm also very interested in this thread because I would like to build a hybrid amplifier.
This schematic was published in a hungarian DIY book.
The tube stage stem from the famous Williamson amplifier with 2 6SN7 tube, and after the MOSFET part is very simple. The book's author wrote that he had built it and its sound was very good. I would like to use rather in A-class accordingly I have to decrease the supply voltage between +/- 12-15V.
Old 2nd November 2006, 02:43 PM   #15
Default nishiki hybrid amplifier
The intention of the so-called Nishiki hybrid amplifier is good sound and performance, this for a small budget.
I used Power MosFets like the BUZ900P and 2SK1058 family before in my hybrid designs, they are easy in use but also expensive. Though they have influence on the overall sound of the amp. An original high-performance power transistor like the 2SC5200 or 2SC3263 is only 3 euro or so, the used quasi-complementary output stage is very neutral in terms of sound and specs. Sound and specs depends on tube which is used, the circuitry and the coupling capacitors. I used several configurations with different tubes. The basic compound circuitry was build using the ECC82, ECC88 and 6N1P, all their own sound balance. All great, just different. I used a long-tail with a DC coupled cathode follower using the 6N3P, the ECC83 and 5965 (all this with a 6N1P as cathode follower), same story here. Balance and behaviour of the driver stage is very quick evaluated.
Lately I do use an ECL82 based driver based Nishiki concept and upto 100 watts distortion is as low as 0.15% (this with no overall feedback) and amp sounds like I know the ECL82; dynamic, no stress, open, great highs and lots of music.
I build several hybrid amplifiers using different driver tubes and different Power MosFets and I feel the Nishiki concept is the better choice. The overall cost will be lower and sound can be very entertaining.
Wim de Haan / NL
Old 2nd November 2006, 02:51 PM   #16
Andypairo's Avatar
Wim,
could it be possible to receive the full schenatic?
If so my address is andrea.pirovano (at) gmail.com
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 4th November 2006, 05:23 AM   #17
Tyimo is offline Tyimo  Hungary
Default Elektor Hybrid
Hi Lineup!
Would you post the output stage's circuit too???
Tyimo
Old 4th November 2006, 05:45 AM   #18
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Looks like Wermona Regent 1000 with tubes and FETs instead of BJTs.
Originally posted by topicreader
Hello!
The Devil is not so terrible as his math model is!
Old 4th November 2006, 09:47 AM   #19
lineup's Avatar
Default Re: Elektor Hybrid
Originally posted by lineup
Okay,
Tube:
PCC88
2SK176 + 2SJ56
Data:
-1.7 dB at 100 kHz
At a real photo!
Hi Lineup!
Tyimo
Was just waiting for somebody to ask.
Sometimes people ask about things
then forget about it all
and my help / service / reply
will be of no use
.... all I did
was waisting some of my precious lifetime
image shows your service man
in october 2006
lineup
lineup
Old 4th November 2006, 11:53 AM   #20
culture is offline culture  Netherlands
if you don't mind (the) dutch....
http://www.elektuur.nl/Default.aspx?...1390&Free=True
also kind of interesting schematic i think
cheers,
c
Hybrid nitelite Tubes / Valves 4 16th November 2013 09:32 PM
the hybrid one arhi45 Tubes / Valves 11 8th May 2007 08:44 PM
Hybrid Ply / MDF ? Renron Multi-Way 5 8th February 2007 10:49 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
Copyright 1999-2017 diyAudio
