Old 20th October 2006, 09:39 PM   #1
Default buzz problem please help...
Hello,
I've done an active filter with cascaded 6dB cells separated by jfet buffer.
The buffer is done with 2 jfets in source follower configuration, one for signal, the second for ccs.
Before the first buffer, the signal is splitted, for the highs and for lows. There is 5 buffers cascaded, so I can rich 24dB/octave with four 6dB. I have a small dc drift after the 5 cells cascaded, something like 200mV (the jfets are matched).
The alimentation is a labo dc supply in + -15V, both channels are on the same alimentation.
The big problem is that I have a big big buzzzzzzzzzzzz on my stax (very good control...) But the buz is there only when I put some cable on the input... when the rca are free, almost no buzz.......
Any suggestions (before I go to battery operationn )
Old 21st October 2006, 05:53 PM   #2
OK.... I went to battery operation....... nothing change, same buzzzzzzzzz.......
My source is for testing a discman with battery....... so the only thing on AC line is the stax...
Nothing is connected on ground, is this the problem?????????
Old 21st October 2006, 06:32 PM   #3
You might try posting a basic drawing of what you're describing. It's a bit unclear. What input are you talking about (connecting- buzz, no connection- no buzz) and I'm assuming the Stax is a headphone amplifier??
Regards, Mike.
"We are all agreed that your theory is crazy. The question which divides us is whether it is crazy enough to have a chance of being correct. " Niels Bohr
Forté 1A - buzz problem!!! lukesound Pass Labs 3 20th February 2009 09:43 AM
opamp hum and buzz problem zeus_threat Analog Line Level 12 31st July 2008 04:34 PM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
buzz problem adason Tubes / Valves 5 16th February 2006 01:17 AM
Oscillating transformer buzz problem, please help! Texaspledge Solid State 8 26th September 2004 10:01 PM
Page generated in 0.09634 seconds (66.26% PHP - 33.74% MySQL) with 10 queries
