High-Voltage JFET
High-Voltage JFET
Old 20th December 2002, 06:53 PM   #1
IIR is offline IIR
Default High-Voltage JFET
Does any one know of ANY JFET that is available for higher voltage applications (140v). Current is very small(less than 1mA).
What is the current state-of-the art?
Thanks!
Old 20th December 2002, 07:13 PM   #2
jcarr is offline jcarr  United States
Depends on whether you really need a JFET or simply a normally-on device. If the latter, and if N channels will suffice, you could look at static-induction transistors or depletion-mode MOSFETs.
Or if you really need JFETs, don't mind a bit of extra complexity, or need both P's and N's, how about using JFETs and maintaining a constant, safe VDS across them by adding bootstrapped cascodes?
regards, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 20th December 2002, 07:28 PM   #3
IIR is offline IIR
This is being used in an application where they will be used to switch a bi-directional AC signal on or off(max 140v @ 500uA). JFETs are nice for this purpose!
The application invloves a large array of piezo actuators that need to be indivually charged and discharged. We want to have one Driver and a row/column switch matrix to select the piezo actuator. Essentially what we have is a large matrix of capacitors. We cant use MOSFETs. The body diode in a MOS FET causes problems with isolation between elements. There is an array of 256 elements. the array has to be scanned at a 6hz rate (about 650uS per element). Switch has to be fast.
Old 20th December 2002, 08:31 PM   #4
Tokin's static-induction transistors may possibly do the job. AFAIR, these are all N-ch depletion mode (normally on) devices, so I hope that is OK with you.
http://tokin.intercraft.co.jp/pdf/sit000001.pdf
Warning. Text is in Japanese.
Incidentally, some of these devices would be interesting to use in an audio power amp, I reckon. For instance, the 2SK181 has a drain voltage of 800V, a max drain current of 20A, and a power dissipation of 300W. OTOH, Gm is 10S, and the Cis is 2500pF, so the driver and bias circuitry may require some thought...
hth, jonathan carr
High-Voltage JFETHide this!Advertise here!
Hi-Voltage JFET's mojoat Swap Meet 1 28th December 2007 10:01 AM
High voltage (>60V) P-channel JFET? PanzerLord Solid State 15 11th December 2003 12:58 PM
Copyright ©1999-2017 diyAudio
