This has been happening to power supply bypass tantalums near an IC (LH0002)on one pcb. This is not audio stuff but an EchoSounder. The 10 ohms resistor in series with this 10 mcf tantalum becomes hot, and the cap tends to fume. Remove the caps on both (+/_)rails and there is no functional problem.
The ES has been idle for some months, not powered. Change the caps to new, same problem. Bypass these caps with another electrolytic, same problem. I am sure many of u know why it happens. The PSU is an SMPS with 24Vdc input. Can anybody explain why? Gajanan Phadte |
#2 |
1) Check voltage and polarity. The real ones, not the supposed voltage, or the polarity silkscreened on the PCB. 2) Check that at no moment during the power-up or down sequence the voltage becomes reversed. If it does, place a schottky protection diode across (1N5820 f.e.) 3) Occasionally, tantalum can be damaged by a current surge, but with 10ohm in series, it's unlikely. LV |
#3 |
The only other possibility is a problem with the SMPS causing HF to be fed through the tants. Unlikely, but if all else seems ok...
| Tantalum | Pbassred | Solid State | 2 | 25th February 2006 07:28 AM |
| Tantalum cap identificaton. Please help. | sv | Parts | 1 | 1st April 2004 01:31 AM |
| Silicone fumes | Flavius | Multi-Way | 14 | 24th June 2003 02:37 AM |
| tantalum | rafafredd | Tubes / Valves | 0 | 8th December 2002 11:51 AM |
| Page generated in 0.07790 seconds (71.86% PHP - 28.14% MySQL) with 10 queries |
