does anyone have spice models for these devices that work good with CIRCUIT MAKER?
2sk170 / 2sj74 2sk1058/ 2sj162 |
#2 |
*2SJ74
*Toshiba Dep-Mode 20mA 400mW LowNoise pkg:TO-92B 2,1,3 .MODEL 2SJ74 PJF(Beta=92.12m Rs=7.748 Rd=7.748 Lambda=4.464m +Vto=-.5428 Cgd=85.67p Pb=.3905 Fc=.5 +Cgs=78.27p Is=12.98p +Kf=26.64E-18 Af=1) *2SK170 * 20mA 400mW LowNoise Dep-Mode pkg:TO-92B 3,1,2 .MODEL 2SK170 NJF(Beta=59.86m Rs=4.151 Rd=4.151 Lambda=1.923m +Vto=-.5024 Cgd=20p Pb=.4746 Fc=.5 +Cgs=25.48p Is=8.477p +Kf=111.3E-18 Af=1)
If you are arguing with an idiot, first make sure that he is not doing the same thing. |
#3 |
thaks a LOT! (boro care! PoZdrav!)
wath about lat.mosfets? |
#4 | |||
I'd like also to get working Lateral MOSFET models. I use Electronics Workbench Multisim. Besides 2SK1058 / 2SJ162, I want: 2SK1530 / 2SJ201 If anybody has got a good models of 2SK216 / 2SJ79 that works with Multisim. I would be most happy! -------------------------------------------------- I tried Netlist contributed 2SK216 model. I am sure it is good. But I just get an error message. What am I doing wrong? Quote:
lineup |
#5 |
lineup,
The last quote in post #4 has a linewrap problem, so if this is what your model statement really is, it won't work. Add a + sign to the 2 line that don't have them. The + sign means "continuation". Rick |
#6 | |||
I don't think so. lineup
lineup |
#7 |
If it is written like your post, it is a linewarp problem. Try fixing it as I suggested.
Rick |
#8 |
This should help somewhat...
*SRC=2SJ76;QSJ76;MOSFETs P;Gen. Purpose;140V 500mA .MODEL 2SJ76 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6 + PHI=.75 LAMBDA=1.48M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46 + CBD=444P CBS=533P CGSO=384N CGDO=320N CGBO=346N) * -- Assumes default L=100U W=100U -- * 140 Volt .5 Amp 6 ohm Enh-Mode P-Channel MOSFET 07-28-1995 * 2SJ76, TOSHIBA, 1993 JAPANESE FET MANUAL, P.16 ********** *SRC=2SJ79;QSJ79;MOSFETs P;Gen. Purpose;200V 500mA .MODEL 2SJ79 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6 + PHI=.75 LAMBDA=1.04M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46 + CBD=862P CBS=1.03N CGSO=57.6N CGDO=48N CGBO=1.09U) * -- Assumes default L=100U W=100U -- * 200 Volt .5 Amp 6 ohm Enh-Mode P-Channel MOSFET 07-28-1995 * 2SJ79, TOSHIBA, 1993 JAPANESE FET MANUAL, P.16 ********** *SRC=2SK213;QSK213;MOSFETs N;Gen. Purpose;140V 500mA .MODEL 2SK213 NMOS (LEVEL=1 VTO=15 KP=.16 GAMMA=18.6 + PHI=.75 LAMBDA=1.48M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46 + CBD=560P CBS=672P CGSO=26.4N CGDO=22N CGBO=852N) * -- Assumes default L=100U W=100U -- * 140 Volt .5 Amp 6 ohm Enh-Mode N-Channel MOSFET 07-28-1995 * 2SK213, TOSHIBA, 1993 JAPANESE FET MANUAL, P.38 ********** *SRC=2SK216;QSK216;MOSFETs N;Gen. Purpose;200V 500mA .MODEL 2SK216 NMOS (LEVEL=1 VTO=15 KP=80M GAMMA=18.6 + PHI=.75 LAMBDA=521U RD=.84 RS=.84 IS=250F PB=.8 MJ=.46 + CBD=658P CBS=790P CGSO=26.4N CGDO=22N CGBO=852N) * -- Assumes default L=100U W=100U -- * 200 Volt .5 Amp 6 ohm Enh-Mode N-Channel MOSFET 07-28-1995 * 2SK216, TOSHIBA, 1993 JAPANESE FET MANUAL, P.38 **********
Non é mai abbastanza... |
| spice models for led | fscarpa58 | Parts | 18 | 10th August 2009 10:16 PM |
| IR driver models | darkfenriz | Class D | 2 | 5th March 2007 09:06 PM |
| anyone have some transformer models? | keantoken | Power Supplies | 13 | 26th September 2006 03:24 AM |
| mje models? | bogdan_borko | Solid State | 2 | 29th May 2006 11:37 PM |
| looking for spice models | bocka | Parts | 16 | 23rd November 2003 02:00 PM |
