And how does it sound? performance? ease of build, ect?
#2 |
Ive built two P101 Mosfet 2-channel High power version they sound fantastic. Very pleased with results. Ive posted pics on esp forum under P101 close to completion. In the amplifier gallery.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#3 |
I had built the project 83 before it was published ...
#4 |
I’m building his “60 watt into 8 ohm load” amp. It’s completed and I will power it up as soon as I get an hour or two. Before I built it I ran it on a simulator and it simulated fine. I made a few changes because of availability of parts (the low power transistors), and I made my own PCB. I’ll let you know how it sounds, provided I built it correctly and the whole thing doesn’t go up in smoke….
#5 |
built p101 as well. only pain i had was that i was used to irfp240's which fit 6-32 screw. tapped my holes for 6-32 and bit of effort getting through. i used the aluminum oxide pads as insulators, easier and less fear of puncturing the silpad often used. thing keeping me from using my a whole lot is i need to put a softstart in as i have a 800va toroid in there - usually can start up as long as no signal playing. thinking bout downing to a 500va toroid as this 800 also vibrates the chassis.... but mine is dead silent clean clear and strong. used 6 x 6800uf elna lpa caps (solen, good price). topped it off with vampire jacks and posts.
#6 |
I built a P101 as well. I was experiencing humming issues, but I'm rebuilding it now to take care of that (think it might have been a wiring issue). These amps are very powerful and very musical.
http://home.comcast.net/~bushroot/index.html The messy before pictures... |
#7 |
Traw, if I may ask, where did you get that chassis? I'm hoping I can find something like it. Thanks!
#8 |
built from scratch. easier with big heavy heat sinks, when you can find them at reasonable price. although the horizontal arrangement of fins zaps 30-40% of the sinks efficiency, still plenty for class AB. makes mounting top bottom plate easier, don't need angle brackets or squre rods etc. also these heat sinks had a hefty 1/2 base. drill n tap, repeat.
#9 |
Okay, I think I see how that works. Thank you for the reply!
#10 |
Bushroot
Hows the rewiring coming along.
| Hi! And I built one too... | The RB | Chip Amps | 4 | 13th March 2009 09:12 AM |
| i built these a while ago and | roystr | Full Range | 11 | 10th November 2005 12:49 PM |
| Who has built their own? | markp | Solid State | 42 | 29th June 2004 09:42 PM |
| Anyone built this amp? | JojoD818 | Solid State | 26 | 19th August 2003 11:32 AM |
| Page generated in 0.10888 seconds (76.57% PHP - 23.43% MySQL) with 11 queries |
