camt1 said:sorry should have explained amp is only being used to drive sub woofers from 90Hz down over , it is being fed from linkwitz rielly crossover and linkwitz transform circiut so it was only at low frequnecies that the lack fo gain was noticable .
camt
Ok,
In that case , I will try 100 or 200 uF...
