100W Amp from car battery as power source
i'm an university undergradute.
i need to build a 100 W Amplifier for a siren system. and the power source should be from the car's battery. i need help. Figuring out the schematic for the Amp. and is it possible to make an 100W amp for the car battery. i need the schematic if there are any, or any suggestion on how to build it. thank you. i eagerly awaits for your comments...... |
A siren will live well with a sqware wives. A car battery gives you 14.4V
Construct a digital "amplifier" with one C-MOS IC with 6 invertors, and 4 FETs on output (2x with P channel, 2x with N channel), and connect 2 Ohm load in a bridge mode. You'll get about 100W of a loud square wave. You even may use this components to construct a complete siren with 100W/2Ohm output, adding couple of capacitors, few resistors and diodes. Google gave me a lot of links, for example: http://www.epanorama.net/links/alarm.html |
Or you may find yourself a car amp which is easily avaible at car accessories shop.
| All times are GMT. The time now is 06:32 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
