Old 17th October 2006, 07:47 AM   #1
Default any theoretical limit on class B power?
ie could you go on for ever bridging and paralleling output devices?
Old 17th October 2006, 08:01 AM   #2
Did it Himself
richie00boy's Avatar
I suppose you could. Remember that to series amp outputs the amps themselves need to be floating.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 17th October 2006, 08:06 AM   #3
pinkmouse's Avatar
Assuming you had an output device that could handle infinite voltage, otherwise you are limited by your device specs and supply rails. Remember Ohms law!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 17th October 2006, 08:22 AM   #4
Did it Himself
No Al you can series amp outputs to get around the device voltage limits. It's not a great way of doing it though, and you need to ensure matched and balanced voltage sharing.
Old 17th October 2006, 08:27 AM   #5
pinkmouse's Avatar
Got any examples? I can't see it being that stable personally, but I'm always willing to learn.
Al
Old 17th October 2006, 08:41 AM   #6
Did it Himself
It's not something I'd do in practice.
Basically you just series connect amp outputs, i.e. red terminal of bottom amp connects to black terminal of top amp. However, both amps must be fully floating with no grounding otherwise you short things out. This usually entails each amp being driven by it's own signal isolating transformer to provide galvanic isolation.
Old 17th October 2006, 09:04 AM   #7
djk is offline djk
djk's Avatar
Early SAE and Threshold had models with three outputs in series per rail. This made sense as some of the outputs back then had SOA curves starting to fold as low as 30V.
I also have a Bozak like that, but it makes no sense here as the outputs they used had good SOA up to 100V.
A good series connected output stage:
http://users.ece.gatech.edu/~mleach/...mp/circuit.pdf
The Heathkit AA1800 was similar to this and ran on ±100V
A Crown VZ5000 will do 4KW (over 500V peak-to-peak) into 8 ohms bridged, and used MJ15024/25 in earlier versions.
Much larger amps exist than the VZ5000 of course, but they may have as many as four rail voltages plus and four more minus.
The Crown is a bridge amp to start, and the two channels are bridged again for 4KW at 8 ohms. How much voltage do you really need?
Old 17th October 2006, 09:11 AM   #8
another way to bypass the inherent device voltage limits is to cascode the devices.
Leach invented his "double barrelled" amplifier to overcome the voltage problem when devices were much worse than are available now.
Eg. two pair of MJL21193/4 can manage good power from +-100Vdc supply rails (350W to 400W into 8ohm).
A double barrelled version could, I suspect, manage good power from +-200Vdc supply rails (1kW to 1.5kW into 8ohm from 3 or 4 quad sets).
The resistive ladder arrangement could easily be extended to a three level cascode.
Another alternative is the switching rails (is it ClassG?) when the high voltage rails only get connected when high output power is called for.
regards Andrew T.
Old 17th October 2006, 09:24 AM   #9
One cannot bridge an amp that is already bridged.
Were they paralleled to enable lower impedance to be driven?
regards Andrew T.
Old 17th October 2006, 09:38 AM   #10
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Linear Switching of rails is referred to be Class-G
Step PWM Switching of Rails is known as Class-H
No, already Bridged amps could be Bridged, Crown does this by adopting the Grounded Bridge Topology and implementing the "Quad Bridging Technique"
CROWN Macro-Tech 5000VZ , QSC PL9.0, Electrovoice/Dynacord P3000 are all Grounded Bridge amps and bridging could be done to already bridged amps....
see the diagram
http://www.diyaudio.com/forums/attac...amp=1150172273
K a n w a r
Power supply current limit for testing kubeek Solid State 1 12th February 2009 09:57 AM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Amplifier Power Supply 101... Theoretical Questions ElectroAcoustic Power Supplies 12 22nd December 2006 06:32 PM
Limit power to 80watts RMS from 180-20,000Hz SkinnyBoy Solid State 6 18th July 2003 12:47 AM
Page generated in 0.10951 seconds (77.44% PHP - 22.56% MySQL) with 10 queries
