I have a AB Precedent series model 1550 that I need to score a schematic for. I have looked on the AB site in their archives with zero luck. They make no mention of this model. Can anyone help me here?
Its about 10 years old according to the date code on the output transistors. They are showing a late 95 date. |
#2 |
Some pictures
Under the model number it says Logic Gated Output |
#3 |
and another
#4 |
picture of damage
#5 |
What's the problem with the amp? Maybe there is no need to have the schematic to repair it. Regards, |
#6 |
The amp is from a local grade school. Unfortunately they had someone who thought they were knowledgeable in audio that tried to drive a dead short on channel two of the AB amplifier. The result as one can imagine was the downfall of ch two. To make matters worse they blew the fuse which was a 10 Amp and substituted a 15 amp in its place and blew it also causing more damage.
It only gets worse from there. Their audio person not understanding the situation paralled the 1st row of delay speakers which were on channel one of the blown amp to main cluster amp overloading it. This is a small system having a main cluster up front on one amp. The second and third rows of speakers were delayed and on channels number one and number two of the AB amp. In addition someone fed the output of the main cluster amp to the line level input of the delays and blew them all to hell. I guess a schematic would be a good thing considering the amount of burned up parts on the board and me not being familiar with this model of AB amplifier. I'm open to any suggestions... |
#7 |
Damage to the amp so far seems to be the bias transistor(2n4920) , one MJ21194 output and two 22 ohm 1/2 watt resistors.
The output stage is 3 pair of MJ21193's and 3 pair MJ21194's. Since one blew I feel they all should be replaced. Any thoughts? |
#8 |
Hi Joe,
As usual, I think you are right. Replace the drivers too. You have some work ahead of you. Are you sure you want to warranty this equipment with "that guy" operating it? -Chris |
#9 |
Hi Chris,
I forgot to mention replacing the drivers but you knew exactly how I think. They are on order also. I would feel better if I just had the schematic for the amplifier. I could go thru it and figure any additional problems that might show up as a result of the damage. I've never seen workmanship like this amp has I have a feeling there will be an additional charge to cover my butt against the uneducated operator. I will warranty my work as usual but like I said ...there will be a little extra in the bill. |
#10 | ||
Hi Joe,
-Chris |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
| Page generated in 0.10501 seconds (87.74% PHP - 12.26% MySQL) with 11 queries |
