I'm in need of a simple one-quadrant multiplier for a bias generator.
I'm aware of the standard opamp with a pn junction in the feedback loop based ones, but I'd rather have a simpler discrete solution. I don't need much linearity, I don't need thermal stability, I don't need accuracy, I don't need a divisor input (Z). All I need is something that can give me approximately X*Y with some speed. Any type of input and output is fine, voltage, current, referenced to any rail, or even to two different rails, any will work. Any ideas? |
#2 |
Voltage into the conduction zone of a diode... (?) Unfortunately, input voltage range would need to be small, and somehow the tempco of the diode would have to be compensated...
Cheers |
#3 |
Hi
The simplest practicable thing I can think of is a differential amplifier whose tail is fed by a current representing one of the multiplicand. The other multiplicand is fed as a voltage to the differential pair. This voltage has to be scaled to be limited to tens of mV at most. Obviously, you'll need some ancillary conversion/level shifting/amplifying circuitry around to inject and extract your signals. Maybe an OTA would be simpler after all? Or a modulator of the MC1496 variety. A voltage divider including a FET maybe, but you'd problems of linearity and large signals handling capability. LV |
#4 | |
Regards Charles |
#5 |
Electrons are yellow and more is better!
Basicly a multiplier is rather easy to design if ytou have low demands.
http://www.national.com/ms/LB/LB-25.pdf http://search.national.com/iphrase/q...ery=multiplier http://www.intersil.com/cgi-bin2/Msm...ERY=multiplier I used Google here and I got lot's of hits. You can also check ICL8043
/Per-Anders (my first name) or P-A as my friends call me |
| VBE multiplier | fglabach | Solid State | 23 | 12th June 2009 04:56 AM |
| Vbe multiplier - bypass cap | Donk | Solid State | 7 | 22nd January 2008 01:55 AM |
| Vbe Multiplier Help Please | mefistofelez | Solid State | 2 | 6th December 2004 06:14 PM |
| cap multiplier or not? | PederBass | Solid State | 13 | 23rd March 2004 06:26 PM |
| Multiplier car amp | Kilowatt | Solid State | 19 | 7th September 2002 02:40 PM |
| Page generated in 0.08765 seconds (71.81% PHP - 28.19% MySQL) with 10 queries |
