Quad 405-2 Problem - Page 3 - diyAudio
Old 12th October 2006, 08:13 PM   #21
tr9 blown
tr10 blown
tr7 ok
tr8 ok
d11 ok
Old 12th October 2006, 08:32 PM   #22
Did you check triac T2?
Old 12th October 2006, 08:40 PM   #23
Yes, T2 seems to be ok.
Old 12th October 2006, 09:14 PM   #24
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Ok, if output transistors are blown, don't switch it on again with a fuse F2 anymore after you replace blown transistors. Your voltage amplifier may not work, or deep minus on output of the OpAmp, so thyristor opens and blows up output transistor.
Connect a bulb instead of a fuse F2 and check VCE and VBE on all voltage amp transistors, from Tr1 to Tr7. And voltages on D5,D6 - they may be open.
The Devil is not so terrible as his math model is!
Old 12th October 2006, 09:28 PM   #25
I'll have to continue this on Monday as I will be away until then and I need some sleep! Thanks to everyone who has tried to help, especially Wavebourn.
Peter
Old 12th October 2006, 09:43 PM   #26
Wavebourn's Avatar
Peter
You are welcome Peter, sleep well!
Old 18th October 2009, 03:52 AM   #27
Default Fuse blowing on QUAD 405
I suspect that one of the 1N4148 fuses need replacement and that the audio output TRIAC T2 has shorted. Regards, Hamad
Old 24th October 2009, 11:39 AM   #28
405man is offline 405man  Scotland
Are you still having problems with the 405-2. My first suspicion would be the output triac T2, this can be disconnected by unsoldering the solder link on the pad next to the output terminal on the board. If you can measure D5,6,10,11 &13 in circuit and they are not shorted they are normally OK. If as you say TR9&10 are faulty then you can remove them and power up the amplifier with no load connected and measure the output voltage which should be zero, if it is I would replace TR 9&10 and again with the load disconnected measure the output voltage. If there is a fault you often find that the output voltage is + or – 50V and you can then work back to find out what is forcing the output voltage away from zero, provided you do not attach a load and both TR9&10 are not short circuit you can usually find the fault by measuring the voltages associated with the previous transistors. I have had faulty protection networks N1or N2 and again the amp will work with these removed, hope this helps
Stuart
Old 7th December 2012, 07:49 PM   #29
Hi
i have reading the post about 405-2 quad amp
i have a problem
i replace main and driver transistors
i put 2sd424 instead 17556 (strange cos my pcb is 12565 issue 6)
40872 replaced by tip42c
op amp was blown, it cause 14vdc in output, i put a new one and output now is 0v
all electrolithic capacitors they was all fail
, 1 triac of speaker conector pcb, remove triac an amp pcb (i don't have a new one at the moment, but is not blow, just in case)
now it work, fuses does't blow anymore, buuuuut
i have distorsion in one channel (in the repaired channel)
its makes me crazy
r37 and l4 blown, i replace r37 and i put a little copper coil in place of l4
i have suspect of SOA network circuits?? or the l4 coil?
i have checked ALL parts, unsoldered from pcb to be sure
any suggestions?
thanks
Old 11th December 2012, 10:28 PM   #30
Originally Posted by cheltok View Post
Hi
i have a problem
its makes me crazy
any suggestions?
thanks
it was the coil
now sounds just perfect
Quad FM4 problem JDeV Solid State 25 22nd December 2014 03:03 AM
Quad esl 63 problem howes hound Planars & Exotics 14 31st August 2009 05:40 PM
quad 44/405-2 another hum problem graeme uk Solid State 8 6th July 2007 06:49 AM
Quad 405 hum problem vzs Solid State 16 7th June 2006 09:26 AM
Quad ESL 63 problem. Please help DirkD Planars & Exotics 9 4th October 2005 02:03 PM
Copyright 1999-2017 diyAudio
