Quad 405-2 Problem - Page 2 - diyAudio
Old 12th October 2006, 12:08 PM   #11
Originally posted by pborlace
TR8 tested and ok.
Peter
Doesn't prove it will work when it has to work if you know what i mean.
Old 12th October 2006, 12:14 PM   #12
Take the good TR8 from the other channel and test again.
It's not much work and it save's money.
Old 12th October 2006, 03:01 PM   #13
I've just replaced TR8 with a new component. I'm getting the same voltage at FS1 and FS2 and FS2 blows.
Peter
Old 12th October 2006, 03:21 PM   #14
405man is offline 405man  Scotland
I have had a faulty SOA circuit fail on several 405-2s These are shown as N1 & N2. These are mounted on 2 small 5 pin pcb/modules. To check you can remove these and the amplifier will operate with out them fitted but will not be protected against over current so do not connect a load to the output.
Stuart
Old 12th October 2006, 03:27 PM   #15
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Now please stop blowing fuses, connect a light bulb accross F2, and switch on your amp.
See what is a voltage across collector - emitter of tr10, base - emitter of tr10, collector - emitter of tr8 and base - emitter of tr8.
Also, gentlemen who criticized Swinik, please show me your "Bridge" on the schematics. The whole patented "invention" is an approximation of a transfer function through the R38 resistor. It reminds me another patent, for the invention of the weapon with a screw-like trunk.
The Devil is not so terrible as his math model is!
Old 12th October 2006, 03:46 PM   #16
Check also t2 on the small pcb board out the speaker teminals.
Old 12th October 2006, 05:48 PM   #17
TR10
b-e = 0.001v
c-e = 0.013v
TR8
b-e =0.015v
c-e = 0.013v
Old 12th October 2006, 05:55 PM   #18
Wavebourn's Avatar
TR10
b-e = 0.001v
c-e = 0.013v
TR8
b-e =0.015v
c-e = 0.013v
Did the current flow through the bulb connected instead of F2 fuse?
Now please check C16 and D11. Also, check if no odd connections between a minus rail and a ground.
Old 12th October 2006, 06:05 PM   #19
Current flowing through bulb.
Voltage at d11 = 0.016v
c16= 0.847v
Old 12th October 2006, 06:09 PM   #20
Wavebourn's Avatar
c16= 0.847v
I mean, check if they are alive and not shorted.
Unplug your amp, let it stay few minutes untill all capacitors are discharged, then check everything going from the F2 fuse, step by step, unsoldering and checking resistance to the ground with a speaker connected, probably D11 is bad, or emitter of tr10 is shorted to the heatsink.
Quad FM4 problem JDeV Solid State 25 22nd December 2014 03:03 AM
Quad esl 63 problem howes hound Planars & Exotics 14 31st August 2009 05:40 PM
quad 44/405-2 another hum problem graeme uk Solid State 8 6th July 2007 06:49 AM
Quad 405 hum problem vzs Solid State 16 7th June 2006 09:26 AM
Quad ESL 63 problem. Please help DirkD Planars & Exotics 9 4th October 2005 02:03 PM
Copyright 1999-2017 diyAudio
