#21 | |
That "impressive chassis" was a pure class A 2x100W with about a kilowatt consumption. It was my attempt to hit the bottom. I did, and discovered that despite my musical hearing is better than an average, I don't hear differences between pure class A and 3-step approximation version of Swinik. It was a hot summer, and I put it in garage, I did not need additional sounding heater when my airconditioning system was broken. Now I think of building 2x500W on the chassis... 6E1P tubes on top of the tower glow and wink impressive, unfortunately I did not take a picture before taking filter cans from it.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#22 | |
![]() If some components are widely available in one field, they are cheaper to use in other. For example, HEXFETs developed for switching power supplies and transistors developed for video amplifiers are cheap to use in audio, together with especially developed for audio Hitachi and Motorola BJTs. Also, vacuum tubes developed for military and TV purposes are cheap and may be well used for audio, together with other cool stuff.
#23 |
ilimzn, my apologies for the "college", you are a brilliant engineer.
To earn an excuse, I'll post schematics of Swinik-II (2-step approximation using modern components) and Swinik-III (3-step approximation wit IR HEXFETs) later. But I am sure, you can design something similar or better using open mind, without looking back over the shoulder to comply with well-established beliefs! ![]() Jogndiy, sorry for partially hijacked thread, I did not expect such discussion posting to your amp hello from 1977! It uses the same voltage amplification stage, but with better impedance matching, taking more power from it. ![]() Impedance missmatch is a common mistake, people often underestimate loss of power in stages getting as the result less dynamic range and more distortions.
#24 |
It is mishmash hungary/russian/poland language, Jacco....
#25 |
Banned
bobby2
#26 | |
It's almost Christmas.
Not so much,.......if it says "ZM" in the corner. |
#27 | |
Hmmm... I'm not sure it works... |
| BiCMOS Bipolar+MOSFET better than MOSFET | lineup | Solid State | 5 | 8th December 2009 11:46 AM |
| Mosfet A40 | MikeW | Pass Labs | 123 | 4th November 2008 05:11 AM |
| MOSFET/MOSFET amplifier | jarek | Pass Labs | 21 | 22nd June 2004 05:04 PM |
| MOSFET Help | hugeli60 | Solid State | 5 | 7th June 2002 11:36 AM |
| The best Mosfet for the ZOZ ? | ralf | Pass Labs | 6 | 9th January 2002 05:41 PM |
