Is a CFP output stage based amplifier worth pursuing ? The design in Walt's book is an op amp (NE540) and CFP output stage credited to Signetics Corp'. The design has 0.02uf capacitance across the vbe multiplier, 500uf across the bias diodes, 0.01uf across the local feedback resistors, and 10pf across the feedback resistor ! The output stage has a gain of 4 ! My first try in LT Spice lead to oscillating output and I have had a look on the forum and it seems CFP output stages are a real pain to stablise. I can't even get the design stable in LT SPice! |
#2 |
Is it worth it?
A good question. About 10 years ago I did a commercial design that was to replace a gainclone type design based on a NS chip. The prototype worked perfectly as designed, no changes needed. It sounded better and cost about the same. Maybe I got lucky. I needed rail-to-rail operation from low voltages and an IC front end, otherwise I may not have used the CFP topology. I ran a voltage gain of 3 in the output stage. It helped to make the IC in the front end slower than the output stage. I used a 5532 to drive MPSA06/56 drivers and 3055/2955 outputs. |
| Output transformer replacement... Worth it? | apehead | Tubes / Valves | 9 | 20th July 2008 02:26 PM |
| DSA interface hassle | borges | Digital Source | 5 | 18th September 2006 07:08 AM |
| Carvin FET 1000 Stereo Amplifier worth fixing ??? | v1d9uy | Digital Source | 1 | 10th March 2006 10:57 AM |
| Amplifier Worth Repairing? | PHilgeman | Solid State | 6 | 8th June 2004 07:07 AM |
| Page generated in 0.05672 seconds (73.12% PHP - 26.88% MySQL) with 10 queries |
