Old 10th October 2006, 11:45 AM   #11
maudio is offline maudio  Netherlands
Default Re: Re: Adding a third input to a differential input stage?
Originally posted by janneman
Seems you are looking for something like this:
Jan Didden
Looks interesting, but ad1830 seems to be obsolete? Can't even find a datasheet. Maybe there are any more recent chips like this?
For the differential amp BB's INA134 could be interesting.
Old 10th October 2006, 02:45 PM   #12
Oops.
AD8130 is a lot easier to find the the 1830
Old 10th October 2006, 02:51 PM   #13
Originally posted by maudio
Oops.
I worked with both Ad830 - AD8130.
Problems arised with the relationship :
max. Inputvoltage / Distorsion / Noise!
Heinz!
Old 10th October 2006, 03:14 PM   #14
maudio:
"The happy result after closing the loop is a flat response to >60 khz using a 1:150 transformer, which normally would be impossible at such high stepup. I have a perfect 1khz square over the esl. It should be possbile to raise stepup even further allowing for more output voltage "
Do You have some more specs from Your transformer
like Inputvoltage, Primary inductance, coupling inductance,
C-Load, Secundary-R....? In short : enough to create a model!
"I can have full output swing up till 2 khz which should be enough"
Hmm...from a more "technical" view not very impressive
Heinz!
Old 10th October 2006, 03:33 PM   #15
This is the model I came up with after extensive measurements on my (diy) trannie. Lprim is around 11mH, Rprim is zero (or very close), Lleak is around 7 uH, stepup around 1:145, Rsec ~ 340 ohm. It's a large c-core with two coilformers. Input voltage: It should handle around 40 Vpp @ 100Hz before hitting saturation.
In series with the primary I have a 2.5 mH coil and a 5.6 ohm resistor.
Agree on that, my guess is that peak levels in music will start dropping above a khz or 2. Hopefully at 6db/oct
But now I am running the thing with music I see it sometimes clips on sharp 's'-sounds in female voices. Then again, my amp still runs of my bench power supply which is a bit underrated for the job. So maybe not al is lost yet
Old 11th October 2006, 02:16 AM   #16
"In series with the primary I have a 2.5 mH coil..."
Good and bad!
Thank You for the model, when I find the time I like to play with it!
Heinz!
JLH with a differential input stage mohan72 Solid State 46 10th September 2008 07:59 PM
Differential I/V stage? And RX input guzzler Digital Source 29 19th December 2006 05:32 PM
Differential input stage Dynsdale Tubes / Valves 8 3rd September 2005 07:29 PM
differential input stage xuesong Solid State 3 27th December 2004 02:08 PM
Page generated in 0.10979 seconds (75.79% PHP - 24.21% MySQL) with 11 queries
