Old 7th October 2006, 08:46 PM   #1
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Default Altec 1590C
I have found some Altec 1590C amplifiers available. Are they worthy of restoration? Are they a source for parts?
I'm asking for your comments before I call them trash or treasure.
Old 7th October 2006, 08:52 PM   #2
...truth seeker...
I continue searching and found this link:
http://www.lansingheritage.org/image...90e/page01.jpg
Old 7th October 2006, 09:35 PM   #3
Ed,
The 1590 series is a commercial amplifier rated at 200 watts. It will drive a 25volt, 70 volt, or 100 volt load. It is not suitable for serious listening in the home environment but rather a modest amplifier for a civic center or mall.
Its heat sinks would make a nice beginning for another project. I've repaired more than my share of this animal. The last two I had on hand I gave away.
Old 7th October 2006, 09:47 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I have one, I want to experiment with it using power FETs and vacuum tube phase splitter. It may be excellent for bas guitar in such configuration.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 8th October 2006, 02:01 AM   #5
anatech is offline anatech  Canada
anatech's Avatar
Hi Wavebourn,
If you're going to do that, why not just buy a Counterpoint?
-Chris
Old 8th October 2006, 05:40 AM   #6
Wavebourn's Avatar
Originally posted by anatech
Hi Wavebourn,
-Chris
Why to buy?
Old 8th October 2006, 10:20 AM   #7
djk is offline djk
djk's Avatar
It would be a waste of time and money to use FETs to re-do an Altec 1590.
TO-3 FETs are quite expensive (the heatsinks are drilled for TO-3). The output transformer core is not sized for full-range hi-fi use, and does not have an air-gap in it. The B+ is quite low for much of anything else, no center-tap.
Some old PA monsters are a good source of parts for a hi-fi amp. In my mind, the Altec 1590 is not one of them. You could knock two of them together to get enough ±V for a 40~50W output stage (direct coupled), and enough power for a 5~7 channel HT rig. I would go BJTs for the outputs though, maybe something like the hybrid in the latest AudioXpress.
The 200W STROM from this same vintage has twice the B+, and a center-tapped transformer. When used with a full-wave bridge rectifier it will give ±75V for a 200W/8R, 350W/4R stereo amp.
Old 8th October 2006, 06:17 PM   #8
anatech's Avatar
Hi Wavebourn,
Why to buy?
If you are going to go to all that work, you might end up with something like a Counterpoint. It would be cheaper to just buy one.
I second the use of BJT outputs. My personal belief is that tube front ends will not drive mosfets properly. You'll end up with something that may almost sound okay.
-Chris
Old 8th October 2006, 10:19 PM   #9
Wavebourn's Avatar
Instrumental amp with tubes and FETs sound better, much better. Counterpoint's design sounded like a poor BJT output, and it was unreliable (I don't mean redesigned version, when he run a service company). Altec transformers are excellent for a bass guitar project, it was specified for 200W from 20 Hz, so will be fine for 41 Hz. Just a plate+filament transformer is needed to power a phase splitter. Also, it has an octal socket on the chassis. I see no problems with TO3 sockets, there are enough space for flat transistors.
Old 8th October 2006, 10:36 PM   #10
djk is offline djk
djk's Avatar
If your serious about trying this, I should offer you my stock of TO-3 FETs. I am never going to use them for anything. Same IRF part used in the Nelson Pass Citation 12 mod.
Altec 601 Ilianh Multi-Way 1 8th May 2012 02:59 AM
Altec 408-A Decker Full Range 0 22nd February 2009 09:30 PM
Altec 811B horns and Altec 414z 12" Speakers xecluded Swap Meet 0 21st September 2008 05:21 AM
altec 807-8z AudioGeek Multi-Way 42 9th July 2007 05:38 PM
Altec 414 barossi Swap Meet 2 19th June 2006 08:54 PM
Page generated in 0.11806 seconds (79.43% PHP - 20.57% MySQL) with 10 queries
