#11 |
A capacitive load adds a phase lag to the feedback voltage.
According to D. Self, lowering the impedance of a speaker using some RC or RLC networks to make it resistive is not a good idea : the amplifier will have to deliver more current which means more distorsion. A good amplifer does not suffer from instability with usual loads. |
#12 |
Hi forr
this is not always true. For different reasons some amplifiers with a large amount of NFB or some tube amp do not like reactive loads. When compare the distortion on a tube amp that drive a inductive load with the same load compensated with a RC network we can see that the distortion decrease.Test this in order to believe....If we speak about sound we can discuss to the infinite Cheers Vittorio |
#13 |
No concern about destroying amps. Even the capacitive version isn't as reactive as many ESLs...and it is the more reactive of the two.
Given other constraints, the XO will be as resistive as practical. The inductive/capacitive question is just an opportunity for me to select the best overall compatibility between speaker and amp. Paul |
#14 |
Is there a model I could use as a worst case scenario for capacitive testing and another one for inductive testing? I think a 220mfd cap across the output may be a bit much for capacitive.
#15 |
Hi d3imlay,
220uF is not a reasonable load for any amplifier. A 45 ° phase angle on your load would be a stressful test for an amp. Resistive loads are the most common, I've heard of people adding 0.22 uF across and 8 ohm dummy load as well. Really, you just have to check your designs into a standard load and provide safety margins. The 0.22 uF cap is more for testing stability. -Chris |
| Active load output stage | croccodillo | Tubes / Valves | 69 | 6th May 2012 01:23 AM |
| Bipolar/MOSFET CFP output stage | ashok | Solid State | 25 | 28th November 2010 09:31 AM |
| bipolar full vs semi complimentary output stage | wleediy | Solid State | 0 | 17th June 2007 02:35 PM |
| Mosfet drive in Vas stage and use Bipolar output | YUTK | Solid State | 0 | 26th May 2005 05:50 AM |
| oscilating in capacitive load | borisov57 | Solid State | 3 | 24th January 2003 12:29 PM |
| Page generated in 0.07378 seconds (72.44% PHP - 27.56% MySQL) with 10 queries |
