popping crackling distortion that clears up after 2 mins Help!!
Old 2nd October 2006, 11:23 AM   #1
Puggie is offline Puggie  United Kingdom
Default popping crackling distortion that clears up after 2 mins Help!!
I'm having problems with a Quad 405 fitted with a frequency splitting board from a rogers LS 5/8 loudspeaker.
when powered up the Bass section pops and crackles quite loudly (almost like electrical arcing) with some background hiss, after about 2 mins it settles down and behaves. I had this problem about 6 months ago and replaced most of the transistors and capacitors (mostly Tantalums which were replaced with electrolytics) which solved the problem but now it has re-appeared, any idea what the problem could be?
thanks
Old 2nd October 2006, 12:14 PM   #2
edl is offline edl  Hungary
edl's Avatar
What's your speakers impedance?
Old 2nd October 2006, 12:42 PM   #3
8ohm IIRC, I tried it on a 4ohm midbass and that is no better/worse.
I have found with just the amp channel and no input I get a little popping and crackling, with the frequency splitter board it seems a little worse (but it may not be).
Old 2nd October 2006, 12:59 PM   #4
edl's Avatar
Hmmm...
Then I would check the solderings, then the elkos.
Or maybe it's oscillating? You should use a scope to determine it.
Old 3rd October 2006, 11:13 AM   #5
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Try this method....and the others ideas people will suggest too.
Touch with a soldering iron the components leads
This way you may find the defective component.
Do it with the amplifier switched on...no signal in the input..and listen to detect the noise..... wait component to absorb the heat from the soldering iron...listen at the speakers searching for the damaged part.
Of course sensitive stages will amplify the AC noise captured by your soldering iron metal chassis....when testing those stages reduce the volume for some seconds...remove the soldering iron and turn the volume up again.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 3rd October 2006, 01:38 PM   #6
I have today found out that tapping that amp board causes the speaker to 'crack' loudly so I think it would very well be a dry/broken joint.
Old 3rd October 2006, 02:33 PM   #7
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Blanket resolder, and go over all the traces with a magnifing glass to check for any cracks.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 11th October 2006, 11:13 AM   #8
Further to this, I have now solved the loud 'crack pop' noises, by blanket re-soldering the board and changing one Tant capacitor for a back to back pair of electros (was all I had to hand). but now the amp has quite a hiss and crackle which fades in at turn on which clears up after 30sec or so, Someone mentioned the electrolytic caps could be breaking down and healing as a voltage is applied, any ideas?
popping crackling distortion that clears up after 2 mins Help!!Hide this!Advertise here!
Diagnosing and fixing amplifier fault (loud crackling and popping) halfgaar Solid State 100 29th January 2012 10:01 PM
Help needed, Primare A10 crackling and popping. Brillegeit Solid State 8 11th December 2011 10:45 PM
Denon pma-1080 cutoff after few mins. Andreash Solid State 5 6th September 2009 07:01 PM
1st ever project finished 2 mins ago - IT PLAYS!! gilbodavid Class D 7 3rd November 2005 09:32 PM
Copyright ©1999-2017 diyAudio
