Weekend just passed and its Monday and what a blue monday it is.
Over the weekend i got all the components for building the M 250 amplifier, im not using a PCB just a simple veroboard. Well after assembling the amp and taking and double checking my work, i turned it on, i used a +/- 30V supply and 100R in series with the supply just to be on the safe side. The problem : Well the green led turned on which indidates the voltage regulator is working, but wait a sec "T2" BC 556B is getting Can someone please help me ? Thanks in advance.
There’s nothing worse than the smell of burned output transistors!! |
#2 | |
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 | |
Means you did something wrong with the diodes or the DC-blocking electrolytic. What kind of electrolytic capacitor in the feedback line did you use ?
Looks like Sponge Bob has killed another thread. |
#4 | |
Electrons are yellow and more is better!
http://www.atjoo.hostiz.com/m250.html
/Per-Anders (my first name) or P-A as my friends call me |
#5 | ||
that has been discussed several times before at www.diyadio.com http://www.diyaudio.com/forums/search.php: M250 M is for Marcus - the name of constructor He was posting a bit as member called: marcus66 http://www.diyaudio.com/forums/membe...fo&userid=3004 For example about his M250 amplifier in this topic: I have updated the M250 amp design (as well as my prototype). Please re-visit the URL posted at the top of this thread for the new schematic. Thanks again to Djk, whose comments have now been put to use. Best Wishes, Marcus Article with schematics + some informations for build published at his homepage: M250 - A 250W stereo power amplifier lineup audio informations
lineup |
#6 |
Here you can have a look and try to see what happens at the schematic. Uses parallelled MJ15024 / MJ150025 output!http://www.atjoo.hostiz.com/schm250.jpg Here you can have a look and try to see what happens at the schematic. Uses parallelled MJ15024 / MJ150025 output!http://www.atjoo.hostiz.com/schm250.jpg
lineup |
#7 | |
I see. Pretty standard stuff. I agree with Jacco's diagnosis, as far as you can tell without any measurements done. BTW That C2 is way to large (or the series R way to small). Any output Z in the driving source or preamp and you lose your top end. Jan Didden
#8 |
#9 | |
#10 |
A quick 'inventory' can be taken by measuring the voltages (DC, against gnd) on the terminals of T1, 2, 5 (no signal, shorted input). That would help us forward.
Jan Didden
| Just wanna say something | shaunly | Multi-Way | 2 | 13th November 2004 06:15 PM |
| win xp antivirus progs dont work | sss | The Lounge | 8 | 12th April 2004 04:02 AM |
| ESP - P68 300W dont work ! help | Dj BASS AMP | Solid State | 20 | 30th May 2003 10:15 AM |
| Wanna see a pic of my subwoofer?? :) | SkinnyBoy | Subwoofers | 54 | 9th May 2003 07:59 AM |
| Page generated in 0.12816 seconds (81.39% PHP - 18.61% MySQL) with 10 queries |
