Hi!
Someone asked me to do a good quality, high power (up to 700w rms), well protected and stable down to 2 ohms amplifier. I would like to get finished modules or at least well teted and known project with pcb available. I prefer d class for this, but it can also be b class. Searching around i found Hypex, B&O, but they seem to be exopensive if compared to used amps. I would like to know if it's worth diy and which circuit or module would suit my needs. Thanks in advance! Miha p.s.:I have no info on speakers for now. Only know it will be also used on 2 ohms. |
#2 |
No one can help me out with this?
#3 |
Did it Himself
I think that trying to run down to 2 ohms is your problem, it's too low. If you can convince your friend that 4 ohms is good then I would look at UcD700 and ZAPpulse 2.3SE. Coldamp also seem good.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Hmm, PA's are very often demanding power amps capable to run 2ohms. Yes, i checked solutions you mentioned, but they seem to be more expensive in parts than factory made amps. I will suggest QSC amps or something similar. After researche i think diy PA amp is to expensive.
Thanks Miha |
#5 |
ESP P68 with enough output transistors can easily do 2 ohms. it doesn't have protection circuitry though.
I have built one that does a little over 500W at 2ohms mono with 5 pairs of output devices. take note this is class B. |
#6 |
We run our big demonstration PA subwoofer in bridge mode with 2 BP4078. It has 2 8 ohm drivers, but as we connect them in parallel, total is 4 ohm.
So each module sees 2 ohm. With only 2 BP4078 and 1 SPS80 we run it at >1200W with no problem. They just need a bit of forced cooling to run music continuously at that level. So yes, they can run at 2 ohm safely. |
#7 |
Ok, thanks for taking your time. I will check this options.
Miha |
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| Pro Amps v Kits, High end modules | Nicos | Solid State | 57 | 4th November 2006 02:39 AM |
| Yamaha 230w 8 ohm professional power amp, cheap as chips | priscared | Swap Meet | 14 | 19th March 2004 12:04 PM |
| Page generated in 0.08081 seconds (83.54% PHP - 16.46% MySQL) with 10 queries |
