Hi! I'm hoping someone can suggest where I should start with this issue I'm having with a used Linn Intek integrated:
When I turn the volume control clockwise from "off", the unit comes off of mute at a very loud volume. Turning it farther clockwise just makes it louder. I can't listen at a "quiet" volume at all. Any ideas on where I should start looking, or what I should test? Any suggestions are greatly appreciated! Thanks, Grainger |
#2 |
I have used a Linn LK1 pre-amp which uses a linear volume control (MDAC) rather than a log one. So the minimum volume setting isn't very quiet although certianly not too loud.
#3 |
Some questions springs into mind;
Have you earlier been able to listen to "quiet" volume with this unit ? Is the sound distorted ? What source are you listen to ?
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#4 |
Thanks for the responses!
Nope, it has been the same since the first time I plugged it in. The sound isn't distorted at all, and it sounds the same no matter what source I have it plugged into. Also, it is the same on both channels. |
#5 |
If you donīt need to listen to loud volume, the easiest way to cure this, is to add a voltage divider (2x2 resistors) on the volume control....
However if you have the schematic, it will be easier to find a better solution
| Linn Intek Schematic required | burbeck | Solid State | 41 | 25th September 2011 03:29 PM |
| linn intek DC on output??? | hemiharper | Chip Amps | 0 | 3rd May 2009 02:12 PM |
| Rane Distribution Amp and Volume Control Knob Problem | koverfield | Everything Else | 5 | 3rd April 2009 03:56 PM |
| linn volume | tobyclem | Chip Amps | 0 | 9th August 2006 11:13 AM |
| volume control problem | mozikluv | Everything Else | 3 | 8th September 2003 08:58 AM |
| Page generated in 0.07309 seconds (72.24% PHP - 27.76% MySQL) with 10 queries |
