how do you get trafos to work on DC?
Old 17th December 2002, 03:49 AM   #1
hacknet is offline hacknet  Singapore
Default how do you get trafos to work on DC?
im got a whacky idea to get power trafos to work on DC? iz this possible?
Old 17th December 2002, 03:51 AM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Default that is oner of the main purposes
of trafos
to get some nice DC
out of that unuseful AC
Old 17th December 2002, 04:23 AM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Default Re: how do you get trafos to work on DC?
If you get it to work, we will want
to see it.
Old 17th December 2002, 04:26 AM   #4
On Hiatus
Default Re: Re: how do you get trafos to work on DC?
to see it.
veru funni
bad boy
Old 17th December 2002, 05:05 AM   #5
MRehorst is offline MRehorst
MRehorst's Avatar
Not possible.
Transformers require magnetic flux in the core to change in order to create "moving" magnetic field that will induce a current in another winding. If you connect DC to one coil in a transformer, the moment you connect it you'll get a rapidly changing flux and so a spike out of another coil wound on the same core, but once that transient dies out (very quickly) you'll get nothing out of the second coil. In the mean time, unless you limit the current on the coil that has DC connected, you'll be heating up the whole transformer, probably to the point of melting the wires. When the wire finally melts through and breaks open the coil, you'll get another massive spike in the magnetic field followed by another spike in the second coil (assuming it hasn't melted yet).
Look here:
magnetic amplifiers and saturable reactors
Look at the stuff on magnetic amplifiers and saturable reactors.
MR
Old 17th December 2002, 05:18 AM   #6
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
im got a whacky idea to get power trafos to work n DC? iz this possible?
Even with putting a lot of rigorous effort into it, I don't think you will ever be able to get a transformer to work with DC.
However, if you search the net, you will find designs using ICs, or mosfets, capable of DC to DC conversion.
What is the application? Audio amplifier for the car?
Brian
Old 17th December 2002, 05:37 AM   #7
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Hey old guys:
How about those Model T ignition coils that had a make and break vibrator. Did they just collapse the field or did they actually switch the polarity back and forth?
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 17th December 2002, 07:17 AM   #8
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
The idea isn't totally crazy. You can transport DC signals through a transformer if it is equipted with a Hall element but this requires active power for the Hall element.
You can transport only AC energy through a normal transformer and that's that! But I must add, as we know of right now. Maybe tomorrow we can.... I'll remember the blue LED (and even white) which were totally impossible to make when I studied semiconductor sience.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 77 pcb's ordered, 77 paid. Still possible to sign up.
Old 17th December 2002, 08:52 AM   #9
UrSv is offline UrSv  Sweden
UrSv's Avatar
Oh, I seem to recall from school that running a transformer with DC was easy. You just have to find an ideal transformer. That's the problem...
/UrSv
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 17th December 2002, 09:54 AM   #10
Thomas is offline Thomas  Denmark
Thomas's Avatar
Maby if you told us what it was for, we would be able to help you some more.
One wild guess:
Anyways, first you need to transform the DC (a car battery maby?)into AC, you can make a nice 50-60Hz AC with a NE555 or similar and power it up with some suitable power transistors. When you got enough power out of your circuit, connect the trafo and be happy. But now you got AC. So, what's the deal? What do you want? No, realy...
how do you get trafos to work on DC?Hide this!Advertise here!
Anyone tried this SE trafos? Ryssen Tubes / Valves 8 1st August 2009 10:58 AM
UTC trafos for sale Jozef Swap Meet 3 20th June 2009 06:54 AM
Anyone tried the SE-RKT toroid trafos at Schuro.de? Alcaid Parts 4 15th April 2009 02:39 AM
Info on IIT interstage trafos? protos Tubes / Valves 6 21st May 2005 02:42 PM
FS: 2 Trafos(1000VA@2x18V) seve Swap Meet 6 6th November 2004 03:08 PM
Copyright ©1999-2017 diyAudio
