I have try to simulate ESP's P37.
http://sound.westhost.com/project37.htm What I find out was: The preamp is inverted. Should I do a inverted stage on the input or the output so the preamp does not invert the signal? Or it doesn't matterif if it's inverted? (The main amp is not inverted)
Roger |
#2 |
Doesn't matter if inverted. Only matters if channels are inverter relative to each other. As long as all are inverted or not or any combination as long as all channels are the same phase by the output.
-SL |
#3 | |
Hi Roger The project of preamp ESP P37 is no inverting ...
Jorge |
#4 |
hi.
Are you one hundred percent sure? I think Q1 inverts the signal because Q1 has about +15V on emitter and the collector controls the base on Q3, which is the ouput transistor.
Roger |
#5 |
He's one hundred percent sure. Look at the orientation of Q3, it's common emitter, not emitter follower.
If your simulation actually shows it as inverting, you've made a mistake in drafting the schematic. Or it doesn't actually show that, and you're just looking at the wrong data. |
#6 |
I don't know why it's inverted.......
Any suggestion?
Roger |
#7 |
Hi, what software is that?
#8 | |
#9 |
The software is Electronics Workbench
http://www.electronicsworkbench.com/
Roger |
#10 |
thanks, downloading....
| DOZ - Death of ZEN amp from Rod Elliot | hifimaker | Pass Labs | 25 | 2nd August 2009 12:58 AM |
| Trace Elliot | BOCHIN | Solid State | 5 | 30th June 2008 11:17 AM |
| Rod Elliot's new Mosfet Amp | AKSA | Forum Problems | 1 | 20th February 2004 08:42 AM |
| Another new Rod Elliot amp! p3B! | Mattyo5 | Solid State | 20 | 27th January 2004 12:45 PM |
| Elliot's 60W AB amp | mrpibb | Solid State | 2 | 29th April 2001 10:51 PM |
| Page generated in 0.09712 seconds (80.27% PHP - 19.73% MySQL) with 11 queries |
