Mark Levinson no:29
Mark Levinson no:29
Old 23rd November 2007, 04:43 PM   #11
Stormrider is offline Stormrider  United States
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
PPA - could i have the schematic as well?
AJ
Old 23rd November 2007, 04:50 PM   #12
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Dudes,
it's much easier and faster to download the schematic from Jan Dupont's homepage, aka ACD
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 23rd November 2007, 06:21 PM   #13
ppa is offline ppa  Italy
Hi AJ, send me your email so I can send you the schematic
PP
PP
Old 23rd November 2007, 06:24 PM   #14
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Default Hi, ppa !
Send me, you know what @
Linkxp@sezampro.yu
Old 23rd November 2007, 08:49 PM   #15
sparkle is offline sparkle
sparkle's Avatar
i believe it is Delta Audio but i can't find there any sch related Mark L.
Old 23rd November 2007, 09:00 PM   #16
stoN_Cold's Avatar
Default Hi to all
www.audio-circuit.dk
They have all schematic what you want.
Regards zeoN_Rider
Old 24th November 2007, 04:33 AM   #17
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
attach a DMM across one of the .22/5W resistors (one of them appears to be R67 or R87) and adjust R72 for about 5mV.
quickie way to adjust for proper bias: (be sure you know exactly what you are doing here before continuing)
1)put shorting plug on input
2) attach an oscilloscope to the output
3) attach a 10 ohm 20W resistor to the output hot
4) attach the other end of the resistor to another amplifier
5) input a 1khz sine wave to the other amp, and adjust the other amp for 10V p-p output
6) observe crossover spikes on the oscope with the oscope set for 1mV/division
7) adjust bias until the spikes just barely disappear
at first glance, one would think "but i'm DRIVING the output stage, and that's a no-no", but you're doing this through a 10 ohm load, very similar to bridging an amp. plus the fact that you're only applying 10V, just enough to get a bit past the crossover region. the amp's output impedance is higher in the crossover region (when underbiased), which is why you get the spikes. once the bias is adjusted properly, the output impedance becomes constant, and the spikes go away. a side benefit of this is that you now have a "direct reading" method of measuring the output impedance of an amp, since this setup reads out 1mV/milliohm on the scope, so a 5mv wave on the scope would mean that your amp has a 5 milliohm output impedance. also, before starting, you want to be sure that your amp used as the signal source also has it's bias adjusted properly
before performing this test on an ML amp, or any other high value equipment, i recommend that you learn and get used to the procedure on an amp you can afford to make your mistakes on, since ANY method of adjusting bias can go wrong, resulting in leakage of magic blue smoke out of several components
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 24th November 2007, 05:44 AM   #18
sparkle's Avatar
thnx
Old 24th November 2007, 10:55 AM   #19
unclejed613 is right, but mark levinson's amp often have more quiescent current in final bjt for running the amps with sonic performances similar to class A amps, moreover, the 29 power supplies is big for this.
PP
Old 24th November 2007, 12:18 PM   #20
I must say the unclejed613 is good method for looking the final stage's minimal quiscent current for running it at effective class AB.
(I hope that is a decent english)
PP
Mark Levinson no:29Hide this!Advertise here!
Can someone help with Mark Levinson JC-2? atlantaudiophil Solid State 30 22nd March 2017 12:53 AM
Mark Levinson 23 highviewvideo Solid State 6 21st December 2006 05:52 PM
Mark Levinson ML3 minorl Solid State 0 6th July 2004 04:59 PM
mark levinson karma Swap Meet 8 8th March 2003 01:42 AM
Mark Levinson ML2 arnach Solid State 7 9th April 2001 04:36 PM
Copyright ©1999-2017 diyAudio
