#11 |
Okay, well.... still getting the sam results after some more probing around.... all voltages look great, but after a while the output transistors keep heating (both banks) on one of the boards...
Unfortunatly i havnt got access to a CRO =[ would be handy... ...and im not really getting when you say oscillation??? in reference to what in the circuit? Cheers again. Nick. |
#12 |
It is possible that one module is oscillating at a very high frequency (possibly Mhz?) and this would not be audible.
But I would do first is measure the voltage across all the emitter resistors (0.47 ohm) on one module and add them all up. Then do the same to the other module and compare. Do this without the input or the output connected. While you do this, try and see if there is a big variance between the resistors also, this will give an idea of current sharing. Cheers Q
http://sites.google.com/site/quasisdiyaudiosite/ |
#13 |
This may work:
Put your finger on the 6R8 5W resistor near the output terminals of the amp. Without any signal going in, that resistor is supposed to remain stone-cold. Any warmth means your amplifier is oscillating. Verify against the other channel's resistor to be sure... Cheers! |
#14 |
Any UK members might be interested that EPE has just reprinted the SiliconChip article, part one this month (circuit etc.), part 2 next month (PCB layout).
But, like others here, I would suggest checking the bias current - you've never mentioned what you have them set at?.
Nigel Goodwin |
#15 |
Hello again all,
Okay? really kinda baffled at the moment? Spent all morning running through some of the above, and also double checking voltages as specified by S/C. Once again everything looking great by the multi metre screen. plug it in, yep still sounds the same, let it run for a while err? hang on? it aint getting hot now? Both channels are sounding rather nice and both are staying in the same heat range (lol, no the other one hasnt heated up to match!) Im still thinking of what ive done? but to be honest all i have done is bolt Q8 & Q9 to the heat sink (was waiting on Nylon bolts to bolt these driver transistors down), and adjusted voltages via VR1 & VR2 ? so if anyone can see somthing there which would do it that i cant see????? Am keeping an eye on things closely regardless though. Now somthing that just jogged my mind... What do people recommend to use as a preamp ? Is there any kits around that would get on well with this amplifier ??? Thanks again for all the help guys! Nick. |
#16 |
Bump...
Things are going great with the amplifier, my my they sound nice! Just wondering what people are using for volume control ? as siad, are there any decent pre-amp kits out there that will work well? Cheers all, Nick. |
| Silicon Chip ULD amp | Greg Erskine | Solid State | 20 | 18th March 2012 03:47 PM |
| Jaycar/Silicon chip Studio 350 opinions? | Optical | Solid State | 18 | 11th March 2009 05:45 AM |
| HEI from June 98 Silicon Chip | AKSA | Solid State | 3 | 1st March 2008 06:31 AM |
| Silicon chip subwoofer controller | pinco | Solid State | 0 | 31st December 2007 07:40 AM |
| (Aus) Parametric EQ from Silicon Chip 07/96? | Cloth Ears | Subwoofers | 3 | 20th April 2007 12:19 PM |
| Page generated in 0.08775 seconds (75.88% PHP - 24.12% MySQL) with 10 queries |
