I already read the thread about the Silonex's Audiohm optocoupler "Lightspeed Attenuator",wondering how about Fairchilds's H11F1???Although the Ron is higher,about 200 ohms.
#2 |
You get poor linearity for any input signal more than +/- 0.02V (see Figure 2 Output Characteristics of Datasheet).
Patrick |
#3 |
Poor linearity is another way of saying distortion
Thanks for the heads up on the lightspeed attenuator thread Those devices are sometimes known as vactrols and used by record producers to get the sound they like using compression, an ugly word for hi-fi enthusiasts. In fact the compressor is also called a joemeek after the legendary record producer who first used the technique. Until I discovered the Silonex parts (perkin-elmer stuff is difficult to get in the UK) I made my own devices using a yellow Led (to match the wavelength of the LDR) a LDR and some 5mm heatshrink sleeve. In the Lightspeed attenuator the device is simply used as a volume control there is no compression. Another way of doing it is here: http://www.maxim-ic.com/appnotes.cfm...te_number/1118 |
| Can I replace transformer drive with optocoupler in halfbridge smps? | lakone | Power Supplies | 1 | 11th May 2009 02:20 PM |
| Analog amp with optocoupler | lumanauw | Solid State | 2 | 12th August 2008 02:36 AM |
| HCPL3100 Optocoupler | Gold_xyz | Parts | 1 | 18th November 2006 06:38 PM |
| optocoupler to eliminate ground loop | ostie01 | Solid State | 26 | 27th March 2006 08:29 AM |
| high speed optocoupler | djdamix | Class D | 5 | 21st April 2005 02:54 PM |
| Page generated in 0.07666 seconds (70.57% PHP - 29.43% MySQL) with 10 queries |
