amigos hola saben quie quiero fabricar o mejor dicho hacer las lineas en un PCB para el amplificador AV-400, si alguien m,e puede ayudar con el diagrama de las lineas, me explico ;por ejmplo que alguien me de un archivo como el de la foto que adjunto aca abajo saludos...
pd: las lineas de ese PCB es de otro circuito someboy can help me with the PCB for myAV-400, i need the lines for make a PCB for the diagram for myAV-400. for example , i adjunt this file for can you see, i need that, but for pcb muyAV-400 thanks friends pd:that lines is another circuit, is only example. |
#2 |
what kind of help are you asking for exactly? Cannot understand what you want to say. It seems to me you are looking for a software that can lay pcb for the AV400.
#3 |
lo que exactamente ando buscando, es que quiero fabricar el propio circuito impreso, para economizar costos, (me refiero que no quiero comprar el PCB original). lo que quiero es comprar una placa de cobre pcb, pero me enreda esto de dibujar las lineas.
mira los siguientes enlaces, eso te explicaran la idea de lo que quiero hacer, saludos. that that exactly am looking for, it is that I want to manufacture the own printed circuit, to economize costs, (I refer that I don't want to buy the original PCB). what I want is to buy a badge of copper pcb, but it entangles me this of drawing the you line. he/she looks at the following connections, that explained to you the idea of what I want to make, greetings. see this links. THIS LINK IS EXCELENT FOR YOU CAN UNDERSTANd, I NEED DRAW THE LINES, but is complicated for my. http://max8888.orcon.net.nz/pcbs.htm http://www.makezine.com/blog/archive...h_a_laser.html http://www.pablin.com.ar/electron/info/varios/pcb1.htm http://www.pablin.com.ar/electron/cursos/pcb/index.htm |
| Page generated in 0.08125 seconds (72.09% PHP - 27.91% MySQL) with 10 queries |
