BOZ off higher voltages?
Old 15th December 2002, 08:15 PM   #1
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Default BOZ off higher voltages?
I'm building a preamp with RIAA and digital inputs as well as normal analog inputs. I've got the RIAA preamp as well as the DAC worked out and am in the process of building, but I've got a few questions for the main preamp part.
I'm planning on going with the Bride of Zen circuit, it's low parts and simple (I'm on a very low budget, so I chose it over the BoSoZ). The only thing is that since I'm on a low budget I'd like to use parts I already have, like a 10k dual log pot on the output instead of 5k as well as a high voltage suply rail. I've got a nice torroid to run it off of, but I'd have to have a suply voltage of 100v instead of 60v. Is there a problem with this? I'd use the IRF610 MOSFET so it'll handle the voltage fine, I'd just have to use a larger heatsink and higher wattage resistors to handle the greater idle-current and voltage, right? There shouldn't be any other problems, but if so do tell me. Since the IRF610 and simmilar MOSFETs preform better with higher voltages it shouldn't affect the sound quality, right? I know I could just bring the voltage down in the regulator, but I feel like that's a waste and I'd rather not go that route.
Old 16th December 2002, 03:06 AM   #2
JoeBob's Avatar
I hate to bump this thread back to the top, but a simple try it, or a forget it would be enough...
Old 16th December 2002, 04:25 AM   #3
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
BOZ off higher voltages? Send a message via AIM to Peter Daniel
I'm using 100k pot at the input and I can't complain. Also, with higher voltages the circuit might actually work better.
To order kits contact me through forum mail.
Old 16th December 2002, 04:28 AM   #4
JoeBob's Avatar
You mean 100k at the input and none on the output? If so, I might go that route since I've got a 100k alps lying around as well. I guess I'll try it and see how it sounds... Thanks again for the reply.
Old 16th December 2002, 04:43 AM   #5
I'm not using a pot at the output. But with higher power amps, or more efficient speakers, you can hear some noise from the preamp. So the best would be placing the pot at the output and fixed voltage divider at the input.
Old 16th December 2002, 04:58 AM   #6
JoeBob's Avatar
Ah, I see. I'll go that route then.
BOZ off higher voltages?Hide this!Advertise here!
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 06:40 AM
higher voltage PS Steven Koay Chip Amps 5 10th September 2003 11:29 AM
BOZ at higher voltages+funky PS anyone? chiggy Pass Labs 3 10th September 2002 01:24 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
