Old 15th December 2002, 07:17 PM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Send a message via MSN to lykkedk
Default Delay on loudspeaker switch on.
I was hoping anyone outthere could help me with this.
I have recantly finished my Leach amp 4.5, but when I turn it on, my 10inch basse's make a little move in, and then out again.
When i turn off, it's the same, just not so much.
I'am sure it's because of the cap's im the PSU, but i would like to awoid this THUMB.
I was thinking on a circut with an ne555 or simmular, an two relay's, one for each channel for cutting the loudspeaker connection immidiatly when turn off, and delayed when turn on.
The cap's I'am using is 4x10000uF, but I'am planning to use 8x10000uF in the future.
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp.
Old 15th December 2002, 07:21 PM   #2
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default Re: Delay on loudspeaker switch on.
I had some thump from mine when I first built it, so I put bleeder resistors on my power supply caps, and I don't have problems now unless I turn it off, then immediately turn it back on. It didn't seem to effect the performance at all.
Here is a pic:
More pics at:
http://brian.darg.net/leachamp-2channel/
Brian
Old 15th December 2002, 07:32 PM   #3
lykkedk's Avatar
Default Re: Re: Delay on loudspeaker switch on.
Yep I know about the bleeder resistors, but how do i calculate the size for 4x10000uF ?
And wattage to ?
Anyway I would like to make this circuit to just make sure, also because I'am building this Balanced Zen Line Stage, whitch has no protection for thumb's on turn on.
I was thinking of making one power-button, at this pre-amp, which also turn on the Leach amp (delayed), so i would be 100% sure -
Allready destroyed one 10inch bass some time ago, with another experiement
Old 15th December 2002, 07:52 PM   #4
fcel is offline fcel  United States
Jesper,
I guess the easiest way is to install Velleman KV-K4700U in your power amp. Here is what it looks like http://www.audioxpress.com/bksprods/kits/kv-k4700U.htm and it provide DC protection too. I install them in my BOSOZ and there is no more turn/off thump. I'm sure there are other better ways but I don't know how.
Another way is to wait for Brian/Jordan design Relay-based passive volume control project I'm hoping their design has capability to short the output relay to ground at turn on/off to avoid turn on/off thump.
Old 15th December 2002, 08:02 PM   #5
BrianGT's Avatar
Originally posted by fcel
Jesper,
As for the kit, it says:
Supply voltage: 220V AC
Did you have any problems with this?
As for the project that Jordan and I are working, it shouldn't be difficult to add the turnon mute.
Brian
Old 15th December 2002, 08:03 PM   #6
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
i have that problem, BUT solved now. im building a simple circuit for turn on thump. I'm using a murcury wetted relay in each of my mono blocks that i built witha simple timer ic 555 with a 10 second time delay that way there is time to let the amp settle down.
J'
I dunnno what im going to do about my aleph's i think i should do the same.
Old 15th December 2002, 08:10 PM   #7
Brian ... even though it says 220v, it is 120v transformer when I got the kit.
Old 15th December 2002, 08:29 PM   #8
Banned
Send a message via MSN to SkinnyBoy
MY amp has a relay.. lol... and for some reason when I take out one of the poweramplfier modules (or when it stops working) the delay to connect the output to the speakers is longer.. :P lol
Old 16th December 2002, 10:05 AM   #9
JasonL - that circuit you mentioned for delay sounds perfect for me - can you post a few more details?
I'm running a computer straight into dedicated power amps in a home cinema system, and am getting a horrible noise through the speakers when the PC is powered on. I'd been thinking of running a relay based mute switch, with the relays powered by a 5v feed from the PC, (so the amps, if on, remain muted when the PC is off) but need that delay.
Old 16th December 2002, 02:52 PM   #10
I have a schematic for a speaker delay circuit on my website (go right to the bottom):
http://www.apcl43.dsl.pipex.com/proj_subamp.htm
It delays connecting the speakers when it detects the AC from the transformer secondary and disconnects the speakers immediately when the AC is switched off.
You can use almost any op-amp you like although I'd avoid using NE55532; to quote Doug Self:
"The inputs are connected together with back-to-back diodes for reverse-voltage protection; and should not be forcibly pulled to different voltages. The 5532 is intended for linear operation, and using it as a comparator is not recommended. "
Nice one,
David.
MOSFET switch used as ON-OFF Delay timer lineup Solid State 4 10th August 2008 07:44 AM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 10:24 AM
switch on delay senderj Class D 9 17th September 2006 09:29 PM
Main switch-on delay tonistefanovski Pass Labs 1 21st October 2005 08:52 PM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 09:23 PM
Page generated in 0.11298 seconds (78.15% PHP - 21.85% MySQL) with 11 queries
