#21 |
Banned
Im going to usea voltage regulator. and bring that down. to about 12V that will work perfectly for my wetted relays and the circuit.
#22 |
Banned
Well as i look through all my books i found a new schematic for my temp controler. It is a small circuit that will work perfect for me im going to use 3 led's 3mm ones all green to go on the face plate of my aleph 2's the pourpose is to tell me the temp after 1 hour. I believe it is sujested for 1 hour For heat up before your going to get max performance out of your amps. Am i right or wrong.? Does any one dis-agree with my idea.
What should i do about turn on thump should i put a relay on the speaker out put just a delay. I have lots of murcury wetted relays i access to. Im building 2 x zen amps ( one Stereo block) ( started need a few more parts ) 2 x av800's 2 x aleph 2's 2 x my dad's designs ( done ) 1 n-channel ( done ) |
#23 |
For my Aleph 2, there is absolutely no turn-on thump at all. I mean without the use of any delay or protection circuit.
#24 |
Banned
realy Hum.... im new to the aleph amps and well i dont know if need any protection. I read some whre that yuo can short the terminals out and not harm any thing in the amplifier. Is that true or Faulse. Not that im going to do so...: O ) ... Have yu done any thing spacial to your amp's to not get any turn on thump.. Yur suppose to use ( grr i forgot the name now )...... GRR.
#25 |
I have written quite a number of posts that I got turn-on thump from my BOSOZ (this is assuming that I turn on the amp first) but for my Aleph 2, there is no turn-on thump at all. So the answer is I didn't do anything special .... not even Pi circuiting for the power supply.
I have installed Vellerman K4700 kit in my BOSOZ because of the turn-on thump that it produces - as I wrote in the beginning of this thread. |
| MOSFET switch used as ON-OFF Delay timer | lineup | Solid State | 4 | 10th August 2008 06:44 AM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 09:24 AM |
| switch on delay | senderj | Class D | 9 | 17th September 2006 08:29 PM |
| Main switch-on delay | tonistefanovski | Pass Labs | 1 | 21st October 2005 07:52 PM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.08923 seconds (64.16% PHP - 35.84% MySQL) with 11 queries |
