Old 21st September 2006, 08:54 PM   #1
markusb is offline markusb  United Kingdom
Question Probably an easy question for some.
Hello all,
Does anyone know what the most likely cause of my sherwood av amp (Newcastle r-925 RDS) beginning to power up from standby and then immediately going back to standby along with loud clicks.
I am ok with soldering and replacing parts but need some pointers in the right direction.
Old 22nd September 2006, 08:29 AM   #2
Send a message via MSN to Makofoed-6sn7
First, this might fit better in the soidstate section.
It sounds like it's going in protect mode. The reason for this is that it is a ofset voltage on the output(Most likely, sometimes it is the protection circuit that is broken, but thats rare.), that might come from blown output transistors or unbalance in the amplifier stage.
Mesure the output transistors.
If some of they are blown, replace the driver transistors also.
Thats what I would have done first, lets take from there shall we?
Best regards,
Magnus
The line under is true
The line above is false
Easy question, sorry jhawker23 Car Audio 2 31st December 2007 04:13 PM
Easy (well not for me) Transformer Question Pyre Power Supplies 5 6th August 2007 01:39 PM
Probably an easy question... maguire Subwoofers 8 18th September 2006 07:23 PM
easy question iLyO Multi-Way 23 14th November 2005 08:23 PM
Probably easy clock question Tor M Digital Source 10 2nd June 2004 08:32 AM
Page generated in 0.07341 seconds (70.66% PHP - 29.34% MySQL) with 10 queries
