#11 |
I have had good results with Onsemi's MBR10100 Schottkys
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#12 | |
Mark Broker
The Geek Group http://www.thegeekgroup.org |
#13 |
#14 | |
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#15 |
Iceman--
Now THAT is a power supply...which specific Schottkys did you use? They look like they might be TO-220/TO-247 packages with some serious heatsinks attached. In any case, I wanna build one for my preamp/headamp! |
#16 | |
I, too, was thinking a higher-value resistor in series would probably help balancing and increase diode life. But I was thinking 100k or more so as not to waste too much power, particularly for a higher voltage, low current supply. Regards, Mark Broker
#17 | |
#18 |
What was the "normal" rectifier in your top trace? 1N4004? Or a controlled recovery type?
#19 |
It's from a standard bridge module (forgotten the part no).
#20 | |
The one and only
Schottkys. He uses soft/fast recovery types most of the time. |
| Fast recovery diodes help / advice please ? | AndrewGM | Solid State | 17 | 15th April 2009 09:39 PM |
| Fast Recovery rectifier diodes | rtarbell | Power Supplies | 91 | 16th December 2008 06:38 PM |
| Nice power supply with fast recovery diodes | peranders | Solid State | 3 | 24th August 2004 03:04 PM |
| 200V 50A Fast Recovery POWER Rectifiers | kilowattski | Pass Labs | 7 | 17th February 2004 04:15 PM |
| Freds Power Supply for Aleph | louischia | Pass Labs | 6 | 18th February 2003 12:43 PM |
| Page generated in 0.11688 seconds (80.39% PHP - 19.61% MySQL) with 11 queries |
