probably a newb question and dont really know if i can ask this here but i am having a problem with my amp. I have a 2000 watt volfenhag amp and when i go to turn on my car it goes straight to protect and the shuts itself totally off. Before this incident occured it was working fine for the most part. I was adjusting my settings around on my amp and it just shut right off. Maybe because it was to hot i dont know. Then it took out my fuse by the battery and unplugged and plugged everything back in and it started to work agian after i had put the fuse in. I notice something that wouldnt happen befor it would go into protect mode first and then work. It work for about 2 starts to my car and now it is just protecting itself if u could give some tip or info on what to do that would be great.
Thank you. |
#2 |
It is possible that the speaker outputs were shorted and damaged
some of the output devices. ? ! Chris |
| Page generated in 0.06158 seconds (69.34% PHP - 30.66% MySQL) with 9 queries |
