poweramp as good as gets for 350w
changes
am still stay at the 2 ohms
i realy think a got it the mj15003 pair only use 150 watt and added a pair
the bais adjustment i lower to 100 ohms every time i adjust it on simulator they would go danger up almost 500 watts
lower the voltage
and few others
  • poweramp.zip
Hi Sean,
neither two pair nor three pair will work reliably into 2ohms from +-55Vrails
3pr 15003/4 can drive 4ohm to 50degree phase angle from +-55V. This will allow most speakers to be driven safely IF you keep the Tc below 50degC requiring the heatsink to be kept below 40degC in the worst operating condition.
Your proposal is getting closer to being workable.
BUT you still have the problem of insufficient drive current upstream.
When are you going to take on board the suggestions?
