Old 24th October 2008, 09:13 PM   #71
forr is offline forr  France
forr's Avatar
I mean left from right.
Old 20th December 2008, 10:01 PM   #72
keantoken's Avatar
Hellooo. I'm sure everyone is still sorta interested in a good CCS.
Below is a comparison. On the left is a CCS from the thread below. Sure it's old, but WHO CARES. IT WORKS WELL. It does better than MikeB's favorite (no. 7).
Constant Current Source article (Old)
On the right is a design of my own. Yes, it has the same temperature defects as usual, but it has excellent characteristics. READ: YOU MUST MUST MUST MUST MUST TUNE R1 TO THE RIGHT VALUE OR IT WILL NOT WORK RIGHT. IF YOU POST THAT IT DOESN'T WORK I WILL POST SAYING THAT IT DOES WORK AND THAT YOU TUNED IT WRONG.
Please read the uppercase sentences in the above paragraph before critiquing my design.
Now, my circuit has the drawback that it doesn't have as good frequency characteristics as most others because the tuning goes off at higher frequencies. This might could be fixed by adding a filter somewhere.
The transistors used here have low beta and low Cjo. I believe this is fair. In my experience, some have shunned designs not knowing that if you used different transistors, it actually works quite well. This is the difference between selecting different transistors for different tasks, and selecting the first one that pops up in the sim menu!
At any rate, circuit and simulation below.
- keantoken
Old 21st December 2008, 01:25 PM   #73
Hi K,
which node does the load connect to?
Why does R1 appear to pass ~5.4mA, but R2 passes ~3.3mA? Surely the missing 2mA cannot go through the bases.
regards Andrew T.
Old 21st December 2008, 07:36 PM   #74
lineup is offline lineup  Sweden
lineup's Avatar
AndrewT
Are you blind
Q1 passes like 2 mA
lineup
Old 21st December 2008, 08:22 PM   #75
Originally posted by lineup
Are you blind
I'm getting tooo ooold for this.
Now, where did I put my other pair of specs?
regards Andrew T.
Old 21st December 2008, 09:36 PM   #76
keantoken's Avatar
In my design the modifications from a normal CCS should be apparent. I only just realized this but you can do the same modifications with the other CCS and probably have a better circuit. Hmmm.
- keantoken
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
AURA 1" searching inertial Multi-Way 15 9th November 2008 02:44 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 09:31 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 07:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 09:42 AM
Page generated in 0.08701 seconds (76.71% PHP - 23.29% MySQL) with 11 queries
