#41 |
Another idea: series RC filter between the anode of the zener to the base of the transistor. 4.7kohms+100uF means very good filtering, and slow start.
sajti |
#42 |
Hmm, can you show schematic ? I am not sure what you mean...
Mike |
#43 |
Unfortunately no. I have no software on this PC, I use now. But it's simple: Simple RC filter between the zener, and the transistor. Series resistor, parallel capacitor
sajti |
#44 |
The Vas is a bigger problem in regard to PSRR. Even a fairly poor CCS in the LTP gives better rejection than a stage that is referenced to one of the rails!
#45 |
Tim, principally you are right. Things look a bit different for symasym...
Attached is psrr for symasym with inputstage removed. (openloop) (green = positive, red = negative) psrr is already >40db, plus symasym's feedback of nearly 60db the psrr would easily be >100db. There are enough amps that would be happy to have 40db closed loop... But any psrr artefact outside feedbackloop can't be compensated. Simming symasym with a virtual spice-ccs gives psrr >80db down to dc. The negative psrr is here dominated by the ccs to the ltp, the positive can be fixed to the same level by cascoding the input devices. Mike |
#46 |
About the VAS vs PSRR...
Consider a standard Lin topology : Diff pair -> current mirror -> VAS with Cdom -> buffer -> driver -> output stage. If you wanna talk about PSRR you've got to consider where the crap coming from the power supply will enter the circuit : * V- variations affecting the CCS biasing the input stage : Moot point. This CCS doesn't need to sit on the V- rail ; it just needs to bias the input transistors correctly, ie. collector of CCS < diff pair tail. Just run it off a RC filtered supply from the V- rail. Also note that this one is not corrected by feedback, but its effects should cancel if the input pair is well balanced and has a current mirror on top. * V+ variations affecting the diff pair : it affects both transistors equally. * V- variations affecting the VAS biasing current source : these should be corrected by feedback, if there is enough feedback at high frequencies. I'd say this one is important. * V+ variations : the VAS sits on V+ but the major source of PSRR loss is in fact Cdom (read Self) which dominates the PSRR of the transistor and the current source below. Again, running low-power stages (input + VAS) off RC-filtered supplies should do a lot for PSRR. |
#47 |
peufeu, you are absolutely right, and i run my symasym frontend from RC filtered supplies. But, these filters degrade for low frequencies...
Anyway, i "solved" the problem, the question was as you pointed out, why the bias change was visible at the output. It shouldn't, as symasym runs perfectly balanced. The solution: I replaced the input devices with jfets... Needs investigation...Attached is actual psrr, green = +psrr, red = -psrr, nicely symetrical... ![]() Mike |
#48 | |
Some thoughts: The bootstrapped jfet CCS is always a very good option for very high OP Z. The bootstrapping fights against the miller capacitance at higher frequencies which becomes + feedback. Use gate stopper on bootsrap jfet. All this is pretty academic anyway because which jfet has suitably high voltage rating for this application aswell as a suitably high vgs to allow headroom for the current setting jfet? Stick with the bjt pair, split the 22k bias R into 2 x 11k. 100uF cap from middle of 2 x 11k to -PS rail. Cheers Terry |
#49 |
you seem to be confused, bootstrapping is not cascoding
in my earlier posts I show both bootstrapping in this instance is moving the voltage of the "other" end of the current source the same as the "working" end at the diff pair emitters This is easily done with a R divder with the same ratio as the feedback network, the bootstrap (small signal) voltage can match the diff emitter V to better than 99%, giving ~ 100x multiplcation of the ccs effective dynamic Z my LtSpice sim doesn't use the best fets for this app, just the 1st pair I grabbed from the default part list a real crd will get close to 10 MegOhm Dynamic Z, bootstrapping the crd would probably be sufficient for just about any requirement, cascoding and bootstrapping a crd with approprialy selectd fet would likely put ccs Z so high that pcb stray C impedance becomes the limiting factor over much of the audio band Quote:
#50 | |
I know and have -used-, (not simmed) both. Some bootstrapped circuits get their origins from Hawksford. Your example shows in fact 2 bootstraps. 1) is, as you say, the feedback R divider forcing theoretically zero voltage swing across the CCS. 2) is actually the 2N4393 gate connected to the 2N5486 source. The R divider from OP is a neat idea. Question is, have you tried it, what does it sound like, how does it affect -actual- performance of amp? Cheers Terry |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 07:42 PM |
| AURA 1" searching | inertial | Multi-Way | 15 | 9th November 2008 02:44 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 09:31 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 07:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 09:42 AM |
| Page generated in 3.73017 seconds (3.55% PHP - 96.45% MySQL) with 11 queries |
