#21 |
For something less complex how about using 2 jfets of matched Idss stacked one on top of the other? This would improve the working voltage to twice that of a single jfet and I think would improve the 56.7 db of one jfet to double or 114 db. Or possibly string 3 of them together? I could be daft.
#22 |
cascoding matching fets is wrong (if you run them at Idss):
http://www.diyaudio.com/forums/showt...442#post333442 |
#23 |
Not what I meant. Imagine stacking 2 CR300 diodes. A good thing or not?
#24 |
It would increase output impedance by a factor of two, but that means 56.7dB+6dB=62.7dB, not 56.7dB+56.7dB. Logarithmic addition is linear multiplication.
#25 |
real world tolerance would prevent series ccs crd connection from helping, the crd with infinitesimally (uA) higher limit current would saturate and look like a sorta nonlinear resistor of low value compared to the working crd MegaOhm Z
#26 |
Good point. The second JFET (the one with a higher Vto) would be better used as a cascode across the CCS JFET anyway. It would provide a lot more than 6dB improvement in output impedance.
#27 |
Yeah, Thanks. In the future I'll think a bit longer before posting.
#28 | |
What is it's application? Many different CCS designs with various strengths and weaknesses. Application will be best decider of what type to use. Cheers Terry |
#29 |
Ah yes, the ccs will be used to feed an input-LTP. In detail, i am trying to build a symasym with optimzed psrr to check the sonic advantages.
Attached is negative psrr of a symasym6, green uses standard 2-bjt-ccs, red cascoded jfet. As you can see, psrr degrades heavily below 100hz, also the normal ccs shows a resonance at 9mhz. The peak at 13hz down shows that there is an additional problem... As i want to publish schematic, i should avoid use of exotic parts, they would be substituted anyway. Mike |
#30 |
MikeB, what simulation software did you use for the initial measurements?
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 07:42 PM |
| AURA 1" searching | inertial | Multi-Way | 15 | 9th November 2008 02:44 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 09:31 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 07:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 09:42 AM |
| Page generated in 0.11424 seconds (75.76% PHP - 24.24% MySQL) with 11 queries |
