#11 |
Account Disabled
#12 |
Thanks jcx, out of words ?
![]() Boot_fet seems to be difficult to feed a diffamp as i can't easily bootstrap to the swinging emitters node, but cascoded jfet ccs seems to be really the king... Mikeks, thanks, i really need to improve my searching skills... Mike |
#13 |
Mike, here is an intresting CCS variation, might be worth investigating further: http://www.elektronik-kompendium.de/...r/curr2pol.htm
Martin Rupp |
#14 |
Hi Martin, thanks for the link. I have a nearly identical version in my collection, except your r3/4. R3 is really interesting, there is a good chance that the ccs would keep closed at startup. I experimented with r4, but all kind of values only reduced quality ?
Mike |
#15 |
I made more sims, also adding the "self cascoding" jfet ccs. (see attachment)
The self cascoding shows an impressive -114db... Than i ran a transient analysis to check stability of these circuits. I quickly rejected the "self cascoding", it has ringing like hell, asking for problems. Also i rejected all circuits showing any ringing or beeing ugly slow, this left over 3 circuits, the zener referenced ones and the cascoded jfet. Number 7 (the cascoded jfet) seems to be best option regarding psrr AND stability. (the most stable one) 2nd choice would be Number 3, simple but efficient and stable. Better than my favourite (until today), the No1.... Mike |
#16 |
Try Supertex DN2540 (3ma), or LND150 (1ma).
In JCX circuit it reduces another -25db or more. |
#17 |
I am not familair with these devices, are these current regulator diodes ?
Mike |
#18 |
#19 |
Ah, depletion mode mosfets.. Thanks !
Mike |
#20 |
R5/R4 = R2/R1 (trimmed R4 for estimated D1 Zener dynamic Z of ~ 15 Ohm)
![]() 1KHz on V4 positive supply probes probes psrr 3KHz at V3 input tests input cmrr plot Id(J2)*1000 for same display/"units" as earlier posts, ~ 115 dB psrr, 140dB input cmrr |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 07:42 PM |
| AURA 1" searching | inertial | Multi-Way | 15 | 9th November 2008 02:44 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 09:31 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 07:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 09:42 AM |
| Page generated in 0.11080 seconds (76.97% PHP - 23.03% MySQL) with 11 queries |
