I read that increasing the bias (provided that the amp does not get too hot of course) often is beneficial for the sound.
Some effects can be noted like low end tightening up, crossover and low level signals distortion reduction, ecc. Is this true? My amp is solid state and cheap but I have notice that it sounds perceptibly better when it reaches a warmer temperature. The problem is that with no signal applied at the input the amp remains basically cold. The heatsink is quite large and I think it could dissipate the more heat generated by the output devices for the bias increasing. I read that most of cheap commercial amps are biased exaggerately low for safer operation and maybe to protect weak components. Typical idle bias current in a class AB cheap commercial amp can be as low as 6mA. I would like to increase the bias current just a bit, in order to reach a higher but steady temperature on the heatsink. I have already read that this practice is not such uncommon. I wonder what should be a normal value for the bias current. The output devices are 15A Toshibas, 2 pairs/channel. Any suggestion would be extremely helpful. If this practice can provide beneficial effects I am willing to take some risks. Thank you very much. Kind regards, beppe |
#2 | ||||
Hi beppe61,
Do not believe everything you read. If in doubt, follow the manufacturers recommendations. -Chris |
#3 |
just to confirm, you have 8 Toshiba 15A devices in your stereo amplifier output stage? What is Iq just now? What are your Vrail voltages? Is it an EF driver and output stage? or a CFP driver and output stage? Is it complementary? or Quasi? If you can keep the sink temperature below 35degC then you could try raising Iq but this is not to gain any benefit from increased temperature but to ensure the output stage does not unbias itself and cause low bias induced distortion .
regards Andrew T. |
#4 |
Did someone say Quasi?
If you have a schematic of the power amplifier we can probably give better advice. Higher biasing can help reduce distortion especially at lower volumes but there is no point in trying to get it from say 0.01% to 0.005%. If you double the bias you will double the heat and double the bias will also increase the residual ripple on the power supply (especially on consumer grade amps). Post a schematic if you can. Cheers Quasi
http://sites.google.com/site/quasisdiyaudiosite/ |
#5 | ||
I see blown amps all the time from guys who thought that 'if a little bias is good, a lot must be better'. Quote:
#6 |
Hi beppe61.Take a trip to www.tnt-audio.com on their DIY article regarding increasing bias of the amp.
#7 |
I seen that article. IMO one of the more irresponsible audio posts I've seen. As was mentioned above the details of the output stage more than a little important. As I recall the the article addresses this little or not at all.
I suspect that there may be a basis for the article in dealing with MOSFET output devices. I'm not sure but I think what happens is increasing the bias moves them closer to class A and move the cross over notches (or "half-notches') away from the zero crossing point. My personal experience trying to set optimal bias on EF output sections is that: A- "optimal" is elusive and requires a lot of fiddling with thermal tracking schemes, B-tyhere is quite a bit more latitude than a lot books and articles would lead you to believe, C- a practical solution is get approximately close to optimal (assuming that's even determinable) and then reduce the bias as much as you can without bringing on audible deterioration -- cooler is better so long as it doesn't adversely affect what you hear. |
#8 |
That tnt-audio article is responsible for more dead amplifiers than I care to count.
#9 | |
Cheers
#10 |
Have in mind that manufacturers go for low bias currents because they don't know the ventilation in your rack, or if you drive small bokself speakers or Maggies!
That is the main reason for the low bias current. My rules of thumb when messing with quiescent current are the following: 1. Don't increase the current with steps higher than 5-10mA 2. Always check the temperature of the heat sinks 3. Heat sinks for B or AB class amps shoud never exceed 50C (empirical rule, based on thermal stability and sound quality observations). 4. An amp designed for 15mA QC will never work reliably with 120mA QC 5. follow rules 1,2,3 and 4! I was in the electronic service bussiness and have seen many blown amps and fried woofers caused by silly tweaks. Your BJT's are probably the 2SC5200/2SA1943 or the 2SC3281/2SA1302. Please post a schematic or make/type of the amp What QC do you have now?
The difference between a kid and an adult is the cost of their toys… |
| Power tube bias increasing with signal. | tubesrock | Tubes / Valves | 2 | 23rd July 2008 03:23 AM |
| Optimus amps - Increasing output | DCJuicer | Car Audio | 17 | 1st July 2008 05:18 PM |
| increasing the bias will cause the amp to..... | frank2395 | Tubes / Valves | 2 | 1st June 2005 12:12 AM |
| Page generated in 0.12762 seconds (84.14% PHP - 15.86% MySQL) with 11 queries |
