Its a douglas Self design.
I beleive you know the schematic but i will try to upload it.
The difference between a kid and an adult is the cost of their toys… |
#2 |
Its actually two monoblocs with 1KVA trans, and 2x100.000uF/80V (United chemicon)
Here is a pic of what it looks like. Sorry for quality. One monoblock shown here. The second one will be ready next week
#3 |
This is the Soft start
#4 |
Looks a little lite on the Heatsink side of things but looking good.
Shawn. |
#5 |
Hmm
Somewhere I have seen this circuit but I can't quite place it....I just wonder what would happen to the bias of Q3 if Q6 were to saturate. Perhaps a seperate bias for Q3 and Q6 would make this a non-issue? Just curious, what would be the difference if you replaced Q8 with a PNP type, use Q5 as the source and Q4 as the mirror, drive the emitter of Q7 with the emitter of Q8(PNP) as a common base VAS instead of a cascode VAS? I have done this and it sounds great, may reduce miller effect but I haven't built a casode VAS to compare. Any thoughts?
All the trouble I've ever been in started out as fun...... |
#6 | ||
haven't tried that, so i can not comment. But, you should always take into considaration the absolute phase of the signal (0 deg, or 180deg.) so, you won't end up with possitive feedback.
#7 | |
As long as the quiescent current remains below 80mA per transistor it's fine (already tested....).
#8 |
and some specs:
145W @8 Ohms (20Hz to 20KHz) 268W @4 Ohms (20Hz to 20KHz) The transf. has a 2x40.5V secondary, and the voltage on the caps is 54.9V with the amp idling. At full power the voltage on the caps drops to 53V @8 Ohms and to 52.4V @4 Ohms. It's the benefits of Overengineering!
#9 |
Hi Johnny1!Have you match the output BJTs???
#10 | |
Of course i have them matched! Not only the output BJT's but also all the complementary pairs. The differential pair and the current mirror BJT's are also matced pairs.
| The beast OTL | daly41k | Tubes / Valves | 0 | 18th January 2009 03:09 PM |
| The Beast... | sklimek | Tubes / Valves | 5 | 29th June 2005 04:04 PM |
| Making a beast of an amp | sbattersby 115 | Instruments and Amps | 29 | 16th May 2005 03:28 PM |
| The Mother of the Beast | Sam | Solid State | 0 | 24th June 2001 02:59 AM |
| Page generated in 0.11325 seconds (78.18% PHP - 21.82% MySQL) with 11 queries |
