Old 12th September 2006, 02:56 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Question grounding scheme
When building some sort of preamp/intergrated amp,with a few pairs of input RCAs,a selector switch or a bunch of relays,what kind of grounding scheme is more suitable,by system or by channel???
Old 12th September 2006, 09:59 AM   #2
Hi leolabs
the better system is to use a bunch of relays that switch (on each input) both ground and signal from the connected source moreover if a tape(or CD)recorder is present, and grounding like only one input present.
The relays must to be connected as closely as possible to the RCA(or XLR)inputs.
Old 12th September 2006, 02:43 PM   #3
since I have never built an integrated nor a pre-amp, a bit of guesswork here, so this is a suggestion.
keep each channel separate.
keep low current, clean grounds separate.
keep higher current clean grounds separate
keep dirty grounds separate (decoupling and relay power).
keep power supply ground and zero Volt commons separate.
keep safety earth separate.
keep each RCA ground insulated from the chassis.
Bring all the grounds (EXCEPT the safety earth) to a single audio ground (central star ground).
You will need to experiment with the order of bolting the various grounds together, but I recommend that the dirtiest grounds start at one side moving progressively through the high current to the cleanest ground at the other side. I use soldered earth tags on the end of each ground, that way way I can add extra grounds to the bolt, or change the order, or remove for maintenance.
regards Andrew T.
Grounding scheme MWP Chip Amps 14 29th June 2004 10:21 PM
Grounding Scheme within a DAC 5th element Digital Source 29 15th June 2004 09:23 PM
Proper Grounding Scheme PaulHilgeman Parts 38 14th October 2003 05:00 PM
PCB Grounding scheme dexter Solid State 2 27th May 2001 02:48 PM
Page generated in 0.06699 seconds (69.70% PHP - 30.30% MySQL) with 10 queries
