Transformer Feedback
Old 11th September 2006, 06:40 AM   #1
SillyCone is offline SillyCone  Sweden
Default Transformer Feedback
I'm planning to build a 200w/ch transistor amp for my DIY
electrostatic full range speakers.
I wonder if there is any benefit in including the 200:1 step up
transformer in the feedback chain, as in tube amps?
regards, Jonas
Old 11th September 2006, 11:12 AM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Theoritically it should have a benefit because it would include another non-linear component inside the feedback chain.
In practise I don't think this would work because the phase shift of the transformer would make the loop unstable.
The fact that it is never done (as far as I know) should be a powerfull omen....
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 11th September 2006, 11:28 PM   #3
DCPreamp is offline DCPreamp  United States
DCPreamp's Avatar
Isn't that what McIntosh does? From what I remember of the last set of schematics I saw, they have a large "autoformer" between the outputs and the 2/4/8 ohm speaker output taps and the 8 ohm output tap feeding back an error correction signal.
Can anyone else confirm this topology?
Old 12th September 2006, 01:20 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
But the problem is,where are you going to get the autoformer???
Transformer FeedbackHide this!Advertise here!
Audio Transformer/Cathode Feedback Info LinuksGuru Tubes / Valves 4 26th April 2009 09:13 PM
Transformer on feedback path NIC1138 Solid State 3 9th May 2007 06:41 AM
Transformer based feedback? bigwill Solid State 25 6th January 2006 08:02 AM
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 08:03 AM
Copyright ©1999-2017 diyAudio
