New to mosfets, need help! - Page 2 - diyAudio
Old 14th December 2002, 07:43 AM   #11
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Yeah... I see your valid points. That's one thing about the Z34 I really noticed, very good frequency response. It was almost phenomenal considering the fact that my amp design is simply the one fet operating class A with a 2SC1116A operating in the current source. Heh, this is my rendition of the Zen since I only felt like using one mosfet and made the current sink out of a bipolar. Perhaps the sound would be better with a mosfet current sink in there.
Later I accidentaly fried my Z34 by disconnecting an output from my computer and causing a bad static discharge right into the gate. I replaced it with the only other mosfet I had here, an IRF730. The 730 sounds good too, but it's made for low current and about 400 volts, not really class A material especially since my setup idles at about 1.5amps. Either way, I'm impressed with the ease of use and simplicity of mosfets.
I see what you mean about any little noises getting amplified greatly. I had this problem when I tried to connect the input of the amp right up to the computer. All that terrible sound card noise was amplified and was very loud and irritating!
I must also ask. what's a good topology to use to make a class A SE amp with BAL inputs? Is this feasible with simple circuitry like that found in the zen????
I want to build a mosfet amp with common drain outputs but still use mosfets in the VAS but I don't want feedback or complimentary output devices. Is it too much to bother running this topology idea in BAL mode?
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 14th December 2002, 08:37 AM   #12
Duo's Avatar
Well, I thought of a good design to use now. I'm actually going to mix the Zen amp with the Son of Zen amp. Basically, I want a differential amp like the s of z, but I want current sinking like in the Zen. That way, I have a more linear style of amp and it's going to be balanced like I want. That way, I'll have a nice low noise amp and still be in class A and SE modes as well!
What do you guys think of this idea???
Old 14th December 2002, 09:58 PM   #13
Hey, any amp you build will probably sound better than a cheap one purchased...
As for fets, they make good output devices, but suffer from nonlinearities and changing DC offsets with changing temperatures (Unless you are using a matched pair, which reduces Offsets)
I think that it is a good idea to use a differential input, and negative feedback to reduce nonlinearities at large signal swings. However, unless you need high input impedances, It may be worth your time to investigate a BJT differential input stage (inherently less offset due to mismatching of transistors).
As for the complementary devices, if you run the FETS in Class AB, with around 50 to 150mA bias current, good linearity can be achieved. Also, negative feedback will help greatly.
As for the current sink, I'm not sure how it will affect sound. From what I've been playing with over the last few days, I'm finding Bipolar current sinks to be pretty good (At least when using a current mirror as a current sink. Again, what I'm playing with are at small signal levels (I out = 3mA). What I'm seeing is around 2-20 uA (F = 500Hz to 500Khz) of change in current for swinging outputs of 20Vp-p (Staying well within the current sink's compliance). At 50Khz, The numbers work out to be 5uA/3Ma or around 0.16% regulation. Not too bad.
I'm Not sure how this will be affected by larger current, but I suspect that performance may improve. Also, you may look into a cascode current source, since that should improve regulation as well.
Fets are nice, since you need no drive current other than to overcome gate charge, and gate to drain and source capacitances. For improved frequency response it may be worth looking at a bunch of fets and selecting them with the lowest drain to gate capacitance...
-Dan
Old 19th December 2002, 12:57 AM   #14
Default Which to use Mosfets or BJT?
Hello, I am new to this DIY stuff just built a LM1875 amp with Class B(AB?) 175 watt Bass section. Am thinking of doing a Class A. Rod Elliot says Mosfets sound like crap. Why does he completely dismiss them? I like the idea of building any of JLH, Zen(FET), or DoZ amps but cannot decide which way to go. Any help on this appreciated. Thanks.
Greg Olsen
Calgary
Old 19th December 2002, 02:49 AM   #15
eLarson is offline eLarson  United States
eLarson's Avatar
Default Re: Which to use Mosfets or BJT?
Greg Olsen
Calgary
I wouldn't let Mr. Elliot's opinion sway you.
He seems to be a passionate guy and I
wonder if something he measured adversely
biased his listening. (Can the Placebo
Effect swing both ways? I would imagine
that it can...)
Give a listen to something like a Pass Labs
Aleph 3 if you get a chance. Or build the
Zen 4 or the "Aleph-X" that is being talked
about quite a bit in the Pass Labs forum
Check out the Class A Amplifier site if you
want to build one of the variations on the
JLH 10 watter.
(http://www.gmweb.btinternet.co.uk/index.htm)
If you can build both, try them out and see
which you like better. (I'm leaning toward
building an Aleph X and one of the latter
day JLH class A amps... hopefully I can
keep the power supply common...)
Erik
Old 19th December 2002, 08:31 AM   #16
Duo's Avatar
I built a new revision of my altered zen concept, it sounds very very good. This time I'm using an old IBM computer PSU, 38 volts @25A. The sound is extremely detailed and musical. The amp simply disappears from the sound. The mosfet is still the IRF730 and I use a high quality sanken 2sc1116a for the current sink and a BC 170B low noise transistor for the current sink bias control.
It seems to have a lot of power and is able to drive very low impedances with ease. I could add extra speakers on top of the original one while the amp was playing and I noticed no volume reduction in the first speaker at all. The current handling is simply phenominal.
As far as I'm concerned, the Zen topology and its concepts are very unique and practical indeed.
Old 19th December 2002, 03:27 PM   #17
Default Hey smart guy in Sask.
Hey Duo you care to share your circuit with a Calgarian? I am still at a look and analyze stage not a design from scratch stage. Any help is appreciated. Thanks.
Greg Olsen
Calgary
Old 19th December 2002, 07:30 PM   #18
Duo's Avatar
I'll definately share it. Later today I'll enter the diagram into my computer and post it in this thread. You'll love the simplicity!
Old 19th December 2002, 07:47 PM   #19
Philo is offline Philo  United States
Duo,
LOL... great signature!
Philip
"If you didn't make it with your own two hands, its not really yours".
Where to buy MOSFETs? goodas Solid State 28 16th May 2014 02:40 AM
What mosfets to use? seafire Solid State 18 25th March 2009 10:44 AM
n/p Mosfets vs depletion mod mosfets marcello7x Car Audio 6 4th October 2006 06:01 AM
Why no MOSFETs? Pbassred Solid State 25 1st February 2004 09:06 PM
hmm.. help with mosfets Colt45 Solid State 5 27th August 2002 08:08 AM
Copyright 1999-2017 diyAudio
