Output power for a power amplifier - Page 3 - diyAudio
Old 9th September 2006, 06:40 AM   #21
Progg70 is offline Progg70  Sweden
Sorry now it's there
Old 9th September 2006, 06:59 AM   #22
myanmar is offline myanmar  Myanmar
myanmar's Avatar
Hello AndrewT
Max 50V p to p.....50v peak / sqroot of 2 = about 35V RMS over 4 ohms is 35 squared / 4 is 306.25 W RMS.Is that true
Sorry for my mistake not 50V p to p.
Max +/- 50V swing saw in oscilloscope.
That will be 100V p to p
100Vpp=50Vpk=50/(root2)Vrms or Vac = 35Vrms
Power delivered into a 4r load is
P=Vpk*Vpk/2/Load=50*50/2/4=312.5W
Maximum current when delivering this power is
Ipk=Vpk/Load=50/4=12.5Apk
That power & I peak cannot supply from my power supply.
I average saw in oscilloscope is +/- 30V
30Vpk=50/(root2)Vrms or Vac = 21.21Vrms
P=Vpk*Vpk/2/Load=30*30/2/4=112.5W
That may be possible for my power supply.
I think I must use sine wave generator for measure true power output.
Is that true ?
Can Output power vary because of frequency ?
Old 9th September 2006, 07:40 AM   #23
Thanks guys!
Every one said that the current was to low. To have the correct current, 3 Amp for the amp is it the same as – 1,5 amp negative side sin wave and + 1,5 amp on the positive side or …? (see picture with red questions.)
How is it with the class B amps? is it -1,5 over the PNP (– side) transistor and 1,5 over the NPN transistor (+ side), (see the picture). How is it with Single end where the whole signal is on one transistor and you have a current source? Should the current source was on the whole current 3 Amp or… (see picture.)
Old 9th September 2006, 08:38 AM   #24
This was not requested but turned out to be usefull!
Adding pk (zero to peak) or pp (peak to peak) as a suffix usually clarifies and avoids ambiguity.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th September 2006, 08:52 AM   #25
Hi Prog,
firstly, get rid of your proposed 4ohm load.
8ohm speakers are a difficult enough load for an amplifier. Designing for true 4ohm ability just makes the job that much harder.
Each supply rail will see alternate peak currents of Ipk. That was the purpose of my presentation style.
The smoothing caps and any decoupling along the route supply most of the current spikes required by the load. The long term DC current comes from the transformer through the rectifier.
regards Andrew T.
Old 9th September 2006, 08:57 AM   #26
Hi Prog,
the ccs shown on your single ended amp carries constant current.
The load current is correctly shown as peaking at Ipk. But the arrow is pointing to the transistor, it should be pointing to the load.
The extra current, to supply the load, comes from the working output transistor.
It's current is Iq +-ILoad and can vary from zero (or almost zero as distortion increases badly as zero is approached) to two times Iq (again almost twice).
So much for all the erroneous references to constant current in a single-ended ClassA amplifier.
regards Andrew T.
Old 9th September 2006, 09:13 AM   #27
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi Progg70, sorry if i sound rude, your questions are too fundamental, you really need to work out them on yourself. Without understanding how all these currents sum up, you will never be able to understand any electronics/electricity. You must learn that by understanding.
A few hints:
- Q2 is reversed, the emitter needs to show up.
- The current through a ccs is constant, that's what makes it a current source.
- Get perfectly familiar with ohms law, I = V/R, V = I*R, R = V/I
- Think of currents like flowing water. You know what current is flowing through the 4ohms. This current needs to be a sum of the currents from both transistors, but don't forget the sign ! (The direction of the current flowing)
An example for the single ended:
- outputvoltage +1v, current through 4ohm is 0.25a, current through upper transistor is 1.25a
- outputvoltage -1v, current through 4ohm is -0.25a, current through upper transistor is 0.75a
Mike
Old 9th September 2006, 09:48 AM   #28
kvholio is offline kvholio  Netherlands
kvholio's Avatar
Kirchhoff's Current law:
http://www.physics.uoguelph.ca/tutor...Q.ohm.KCL.html
With kind regards,
Klaas
Old 9th September 2006, 10:03 AM   #29
destroyer X's Avatar
Default You are a Jerk...as you can see, there are multiple visions about the subject
There are many variables that can fool the basic calculations, and even those calculations produce different results ..many results are provided by experienced people here.
The Watt meter will give the correct answer...we can go close with calculations...but as you see...where is the rigth answer?
I receive critics because made errors, if only perfect people could write in the forum you probable will se nobody...if we acept that there's a single correct answer, there are many making errors.
There are simple questions that have not a simple answer, as depends of this and that.
This show us that we have the need to exercise to be humble, as this simple question is showing me, and i hope showing to you to, that the correct answer may depends from other factors, and to colect all them is not so easy.
My vote goes for Michael, as the one has a lot of practice, not only theories...the one know the differences between calculations and real world data resultant of meterings....The humble factor in my point of view.
But, there are in this thread another practice monster...Anatech, this one had reparied more amplifiers than many of this thread could ever see in their lives...and one incredible good engineer, Janemann, as he is one of the forum references... and there are others that i did not mention.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 9th September 2006, 10:33 AM   #30
Thanks everyone! ;-)
I think I have to build and test the circurit to get the right values for the current, watch it in real time and make the curve looking good.
A lot of speakers go down to 4ohm and below in different frequency areas.
Power Amplifier Output Topologies danville Solid State 58 7th March 2010 05:40 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Power Amplifier Output Protection kosalev Solid State 2 16th November 2007 11:39 AM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Increasing Power Output of a Car amplifier Dj BASS AMP Solid State 5 5th October 2002 11:37 PM
Copyright ©1999-2017 diyAudio
