Cheapo amp project help pls - Page 2 - diyAudio
Old 7th October 2001, 12:48 PM   #11
They shipped my samples, be getting them tomorrow.
I live in Singapore(where the National plant is) and its amusing that they advertise a 24hr shipping to the US and a 3-15 day shipping to another part of Singapore. Maybe the US does get priority over us locals after all.
Going shopping for parts tomorrow, here's a list of what I'll buy, hoping for some remarks and tips before spending the cash.
1) I can't afford the 36+ bux it'll take to buy boards from Elliot. It'll probably put me off budget, so I'm thinking of point 2 point wiring, like the Foreplay and Paramour preamps and amps, using 18 gauge solid OFC throughout. Is 18 gauge overkill, cos I'm not very confident at soldering IC leads, or should I use a lower 22 gauge for the ICs themselves?
2) If I do point 2 point, should I use veroboard, or use a board with holes for mounting, but no copper conductor?(2nd option cheaper by a few bux)
3) I have no idea how to mount the parts together, planning on using LOTS of tape. advisable? or should I use some sort of glue instead.
4) ESP doesn't tell me of any test points, how can I test the circuit before running the electricity?
5) How do you heatsink an IC, I have no experience in this. The last time I heatsinked something was my CPU and it had clamps for me.
6) How much do those metal film resistors cost anyway, and is the added 1% accuracy essential to the circuit or just a good thing to have? Whats the difference between metal film resistors and carbon ones anyway.
7) When I remove the transformer from the scrapped amp, how do I discharge the capacitors around the transformer? I'm worried because I've had a screwdriver blown to bits when I discharged a Flash camera cap. I suppose the powersupply cap would be much more dangerous & destructive.
Thanks a million paulb! I'm learning as I go along, and I've learnt much about audio already.
Old 7th October 2001, 04:25 PM   #12
paulb is offline paulb  Canada
Whoa! Let me try to address these:
1. I really recommend a PCB for the LM1875. It can easily oscillate if you try to wire it pt.-to-pt. The leads are fragile, so you can't really solder wires (especially 18 ga.) to the leads. And the leads don't quite match the hole spacing in veroboards, etc.
18 ga. solid wire is hard to work with. I suggest you use it only for power supply and speaker output wiring.
2. But you can do it using a veroboard or just a perforated board. Read the National datasheet carefully for layout precautions, they're important.
3. If you don't go with a board, use your imagination. Tape, glue, stuff hanging in free space...
4. The only way to test it is to power it up, check if the current consumption is what you expect, check for oscillation at the output (if you have a scope), then run audio into it and check the output for sound. If you have access to a current-limited power supply, this is great. Some people wire their transformer in series with a light bulb for the first test.
5. The LM1875 is in a transistor-type package (TO-220). You can bolt it to a chunk of aluminum (use an insulator and heat sink compound) or buy a (fairly large) heatsink.
6. Metal film are supposed to sound better. I don't know if I can tell the difference. You don't need 1%, at least not in this circuit.
7. You can discharge them using a resistor first (100 ohms or so?), then use a screwdriver. The caps in these receivers are fairly low voltage and leaky, so there's not much danger like there is in a TV set (or flash camera). But if you don't like sparks, use a resistor first.
Don't forget to have fun!
Old 7th October 2001, 05:32 PM   #13
how large is enough for an IC thats only 1.5cm?
I can't imagine how it'll support a pentium class heatsink
thinking of lying it flat on the board and just clamping the heatsink down with suitably sized screws...
Will RAM sinks work? They look the correct size and have thermal epoxy bundled with them
Old 7th October 2001, 06:35 PM   #14
Geoff is offline Geoff  United Kingdom
For heatsink types, sizes, mounting methods etc see:
http://sound.westhost.com/heatsinks.htm
Old 7th October 2001, 06:53 PM   #15
Use the datasheet to tell you how much power the chip will dissipate, based on what DC voltage you're supplying it with and how much power you're driving into the speaker. Then choose the heatsink.
Old 10th October 2001, 01:47 PM   #16
Progress...
I've been looking at capacitors, resistors being rather clear cut and inexpensive.
Is there a difference between General Purpose resistors and the Plastic film types? I can't seem to find plastic film ones that are non metallized and go high enough to .22 and 2.2uF. Anybody has any good online stores to reccomend, MECI.com only sells them in 100pcs no mixing .. which is 90 more than I need.
Old 11th October 2001, 11:08 AM   #17
More Progress...
I just went to buy my caps and resistors. Amazed cos the parts cost only 10 bux with board and large caps.. but disaster struck when I asked for a 200VA 10A 18-0-18 transformer. The guy laughed and said that you'd have to order one, and It'll have to be carted to your house.
So. now, what kind of transformer should I get, and I'm sure it isn't 200VA 10A 18-0-18
the most powerful ones I saw were 50VA. would that be enough?
Old 11th October 2001, 11:10 AM   #18
Of course, I couldn't find metal film 1% ones, and I could only get EC caps, not plastic ones... but if it works, then I'll go and mass produce them and give them to friends.
Old 11th October 2001, 01:27 PM   #19
A 150 VA transformer should be enough. It's not that big, your sales person seems to be confused.
The "10A" part was wrong, though. 150 VA, 36 V = 4.2A. It will probably be more expensive than the rest of the parts.
You can use a lower voltage supply, getting less power out of it (and needing less VA). The LM1875 is pretty versatile that way. Check the datasheet, you should be able to figure out what you can get.
A 50 VA transformer could probably get you 5 watts per channel or so. You'd be surprised how loud that actually is.
Old 11th October 2001, 03:14 PM   #20
What about buying seperate 50VA transformers to drive a single channel each? Would that be possible? and can I run such a setup with both transformers connected in parallel?
2nd) should I parallel a few 1000uF caps to get 10,000uf
or would a 5,000uf cap be good enough? I''m planning to build the transformers and caps seperately, and run a power cable to the amps.
Cheapo Guitar Amp sorenj07 Instruments and Amps 9 9th May 2007 07:28 PM
Gc with cheapo components rs1026 Chip Amps 25 7th November 2004 08:46 AM
50W Amp project, no more cheapo. downhere Solid State 25 23rd November 2001 05:27 AM
Copyright 1999-2017 diyAudio
